[Mapbender-dev] AJAX client/server interface
Christoph Baudson christoph.baudson at wheregroup.com
Thu Jul 3 09:22:25 EDT 2008
Up to now, Mapbender passes random data structures during AJAX calls.
You always have to write the same data handling functions over and over
again, error-checking etc.
It would be nice to have a standard data structure that is passed
between client to server and vice versa. If these were always of the
same structure, we could add functions that would do the obvious
error-checking and (de)serialization.
At the moment I use these, please tell me what is missing, or if I'm
completely wrong.
To send from client to server:
queryObj: {
    command:"a string that tells the server side what to do with the
parameters",
    parameters:{
       // data
To send from server to client:
resultObj: {
    success:boolean,
    message:"an optional message for the client to display",
    data:{
       // data
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
