[Mapbender-dev] GUI elements
Arnulf Christl arnulf.christl at wheregroup.com
Mon Jul 7 11:35:56 EDT 2008
Christoph Baudson wrote:
> How about this motion?
> There have been no votes yet. Let's extend the voting period until July
> 21st. If no votes have been cast until then, let's abandon the motion.
> With the separation of "gui_element" into "element" and "gui_element" we
> would have control over the modules delivered with Mapbender. These
> could be certified modules and their core could not be altered.
> Mapbender is very error prone because it gives administrators way too
> much freedom to misconfigure their applications. It would also make
> updates a lot easier.
> Maybe people were more enthusiastic if we deferred the split into two
> tables? Maybe we add a read only column, and the read-only column only
> affects certain columns. Redundant, but people don't seem to like
> changes. :-)
> I still think it's a necessary step and in my opinion ignoring it is not
> an option. But please prove me wrong.
> Christoph
+1 Arnulf
> Christoph Baudson schrieb:
>> Marc Jansen schrieb:
>>> Hi all,
>>> the proposed changes will influence mapbenders structure heavily...
>>> so all of this is due in version 3.0, right?
>>> As for the motion I have some further questions... sorry if they have
>>> already been answered previously, I'll vote quickly when everything
>>> seems clear to me:
>>> ad 1) I like the motion alot, but does this mean that every
>>> "application_element" is inherited from an "element"?
>> Yes. The columns of gui_element are split into two tables element and
>> application element. There is a 1:n relation of element to
>> application_element, which means that a single element can exist in n
>> configurations.
>>> Or is it more like: There is a "element" "mapbender_logo" (unique to
>>> all applications) another "application_element"
>>> "logo_of_certain_application" (unique only within this application).
>>> I could modify certain attributes of both fo my application and these
>>> changes would then be stored as application_element settings, right?
>> I think that's not what I meant.
>> An application would contain application elements only. But these
>> application elements are inherited from (globally unique) elements.
>> Take the logo element for example. The element would contain the
>> columns which should be constant (e.g.  JavaScript, elementId etc).
>> Application_element would contain the columns which are configurable,
>> like position, image src, title etc.
>> A proposal for the split is here
>> http://lists.osgeo.org/pipermail/mapbender_dev/2008-April/001137.html
>> Let's discuss if this is the way to split...on a second thought,
>> "e_url" (URL to help site) would better be stored in application_element.
>>> Where would you save the "logo_of_certain_application"? As a new
>>> element AND as a new application_element? Sorry, I'm confused
>> If you wanted to modify the certified logo element which is delivered
>> with Mapbender, you would only be able to modify the application
>> element settings. So there would be a new entry in application_element
>> only.
>> If you wanted to generally change the logo element, you would have to
>> copy the element and rename it. Then you would deal with a
>> non-certified element! This would create a new element, and if you
>> loaded it into an application, a new application_element as well.
>> The main idea is quality control. If you change the "application
>> element" settings and the application fails, it's a Mapbender problem.
>> If you change the "element" setting and the application fails, it's
>> your problem. At the moment we are unable to detect if anyone is
>> toying around with the elements that came with the release. It would
>> be nice to prevent it in the first place.
>> You see that it will be easy to automatically update elements that are
>> certified. Customized elements (manipulated copies of certified
>> elements) will NOT be updated! The user has to update these manually.
>> It would really make it easy to identify an element. It would consist
>> of a set of files (with a checksum for each file):
>> With the checksum we could identify if the files belong to a certain
>> version: when building a release, an automated routine would generate
>> checksums for all files. Somewhere we would have a list (XML) of all
>> elements with the files they use (including an SQL for element
>> creation!). So an element in a certain Mapbender version could be
>> described precisely by these files and their checksums. An update
>> routine could match these checksums to determine what the status of
>> Mapbender is. In other words, we would have sth like module version
>> numbers. (You could also easily identify obsolete files too, now you
>> can't).
>> Idea: For creating the dump for the release, we could have another XML
>> (created by a Mapbender administration interface), that states which
>> application holds which elements + links to SQLs of their
>> configurations. The build script would then parse these XMLs and
>> compile the dump dynamically. The same could be done for services,
>> i.e. a context document storing the whole GUI WMS data.
>> I'm not sure about calling this 3.0, and what the implications are
>> when calling it 3.0. I would just like to have that as soon as
>> possible, preferably now, as our GSoC students could work on it. We
>> could maintain the old version and slowly build the new one parallel.
>> We could have an incubation process for modules to have full quality
>> control. People could use this new version (maybe 3.0) although it
>> would only contain a single map application and a single
>> administration application, each with only a few modules.
>> I think it's time for another dev sprint :-)
>> Sorry for my verbosity
>> Christoph
>>> ad 2) In bundle with 1) this makes perfect sense...
>>> ad 3) I like that a lot, too. but this is certainly a 3.0-thing,
>>> isn't it?
>>> Bye,
>>> Marc
>>>> Astrid Emde (WhereGroup) schrieb:
>>>>> Hello devs,
>>>>> I second Christophs motion. Let's vote.
>>>>> 1.)  +1
>>>>> 2.) +1
>>>>> 3. ) I am not sure what this means in detail and how this "light"
>>>>> version  could look like. need some more concreate description on
>>>>> this.
>>>> I think of it as the core. We could take this as an opportunity to
>>>> build new application templates. We could start with a single basic
>>>> application, and incubate the necessary modules. During incubation
>>>> we could also apply more quality control, like code conventions,
>>>> updating interfaces or removing redundant code. Incubation would
>>>> also include creating a new administration interface (maybe this
>>>> could be Len's job).
>>>> I'm not sure if it's too much but Mapbender has a lot of bloat which
>>>> makes it VERY hard to add innovations. By starting a light version
>>>> we could get rid of that bloat.
>>>>> best regards astrid
>>>>>> I think it's about time we make a decision
>>>>>> <motion>
>>>>>> I motion to
>>>>>> 1) split "gui_element" into "element" and "application_element".
>>>>>> This implies:
>>>>>> - "element" is globally unique
>>>>>> - "application_element" is unique only application-wide (like
>>>>>> "gui_element" was)
>>>>> you have to make sure that every element in table element has an
>>>>> entry in table application_element.
>>>>> e_src - should be part of application_element ( we have to get rid
>>>>> of the iframes first)
>>>>>> 2) add a "readonly" column to element. This implies:
>>>>>> - You can't modify or delete "readonly" elements
>>>>>> - You can only modify or delete your own elements
>>>>>> - You can only modify "readonly" elements via
>>>>>> "application_element" settings
>>>>>> 3) The above changes have severe consequences. A lot of scripts
>>>>>> are affected. My plan would be to set up a "light" version of
>>>>>> Mapbender with a single admin and map application, and slowly
>>>>>> incubate other modules into this version. Users could still work
>>>>>> with the 2.5 series while incubation is in progress, but devs
>>>>>> (including the GSoC students) could focus on the "light" version.
>>>>>> </motion>
>>>>>> Slimming down Mapbender would have a lot of effects. We could
>>>>>> - have trouble with a lot of merging
>>>>>> + get rid of deprecated files
>>>>>> + reorganise the file system
>>>>>> + add changes quickly (less files are affected)
>>>>>> + make it easier for our GSoC students (they could work in a less
>>>>>> complicated environment and have clearer tasks)
>>>>>> + eliminate iframes
>>>>>> + move SQL statements from dump to modules, and compile the dump
>>>>>> with a build process (less error-prone)
>>>>>> This is not a motion that you should nod off with a casual +1.
>>>>>> Voting 0 is acceptable yet not helpful. Voting -1 implies you
>>>>>> present alternatives or reasons why to stick to the current model.
>>>>>> The only -1 I could think of are insufficient funding and
>>>>>> backwards compatibility, yet I see more pros than cons. I see it
>>>>>> as an investment that will pay off in the near future.
>>>>>> Please vote +1, 0 or -1, don't be shy to use either option.
>>>>>>>> In order to enhance the modular character of Mapbender, I
>>>>>>>> propose to split the database table gui_element. The problem
>>>>>>>> with the current table layout is, that there is no table for
>>>>>>>> "element", just gui_element (From now on, whenever I speak of an
>>>>>>>> "element" (as in "gui_element") I refer to it as a "module").
>>>>>>> I think this is a severe change to the concept of application
>>>>>>> elements. Formerly, copying an application element has been a
>>>>>>> copy "by value", meaning a completely new set of element
>>>>>>> settings. You can have two application elements with the same ID
>>>>>>> that are yet quite different.
>>>>>>> The new concept would imply copy "by reference", so altering a
>>>>>>> copied element (without changing the id) would result in changing
>>>>>>> the original as well. However, this would only be the case for
>>>>>>> the element settings, and not the gui_element settings.
>>>>>>> An example for the new "by reference" logic: There is an element
>>>>>>> called "back". You copy it and modify only its "top" and "left"
>>>>>>> settings. No problem with the original, as "top" and "left" are
>>>>>>> both gui_element settings. Now let's change "HTML-TAG": This
>>>>>>> would change the original, as it is an element setting (and not a
>>>>>>> gui_element setting).
>>>>>>> Now let's assume the element back was tagged "read-only". If you
>>>>>>> would copy the element, you were to choose if you wanted to use
>>>>>>> the original module (and ONLY alter gui_element settings like
>>>>>>> "top", copy "by reference"), or if you wanted to create a new
>>>>>>> module based on the original, with a new ID (and so being able to
>>>>>>> edit the element settings like "HTML-TAG" as well, copy "by value").
>>>>>>> For read-only elements, "by reference" could be the default copy
>>>>>>> option, for other elements "by value".
>>>>>>> An important issue are element vars. Now we only have
>>>>>>> gui_element_vars. Do we still need them? Or is element_var
>>>>>>> sufficient? I guess so. Because by altering element vars, you
>>>>>>> alter the element itself.
>>>>>>> The new database structure could look sth like this, let's
>>>>>>> discuss it because I'm not 100% sure about some fields:
>>>>>>> element:
>>>>>>> e_id
>>>>>>> e_comment
>>>>>>> e_element
>>>>>>> e_src (? - for images it would be better suited in
>>>>>>> application_element, but for iframes :-/)
>>>>>>> e_attributes
>>>>>>> e_content
>>>>>>> e_closetag
>>>>>>> e_js_file
>>>>>>> e_mb_mod
>>>>>>> e_target
>>>>>>> e_requires
>>>>>>> e_url
>>>>>>> e_readonly (THIS WOULD BE NEW!)
>>>>>>> application_element (fka gui_element):
>>>>>>> fkey_gui_id
>>>>>>> e_public
>>>>>>> e_pos
>>>>>>> e_title
>>>>>>> e_left
>>>>>>> e_top
>>>>>>> e_width
>>>>>>> e_height
>>>>>>> e_z_index
>>>>>>> e_more_styles
>>>>>>> element_vars (fka gui_element_vars):
>>>>>>> fkey_e_id
>>>>>>> var_name
>>>>>>> var_value
>>>>>>> context
>>>>>>> var_type
>>>>>>> I guess what I really want to say is that the gui_element_id is
>>>>>>> not sufficient, we need element_ids for real control over the
>>>>>>> modules in Mapbender. Class dismissed...anyone still awake? If
>>>>>>> yes, please comment.
>>>>>>> Christoph
>>>>>>>> So if you have to change a module, the changes do not propagate
>>>>>>>> throughout Mapbender. You have to edit the settings in every GUI
>>>>>>>> manually, it is harder to track module changes.
>>>>>>>> Currently it's not possible to set a version number on a module.
>>>>>>>> So you also do not know the compatibility status of a module.
>>>>>>>> Some only work with specific versions, for example "set_locale"
>>>>>>>> will require Mapbender 2.5, it should not be possible to load it
>>>>>>>> in an older Mapbender.
>>>>>>>> We need a centralised spot for keeping modules. Like an Eclipse
>>>>>>>> update: You open your admin GUI and get a message about new
>>>>>>>> available modules. Currently, you can only copy a GUI element
>>>>>>>> from another GUI. Imagine, Mapbender could load it from
>>>>>>>> mapbender.org. We would have enormous quality control over the
>>>>>>>> modules in distributions.
>>>>>>>> Another problem is module IDs, the same module can have two IDs
>>>>>>>> in two separate GUIs. IDs should be unique at all the time. If a
>>>>>>>> user created a new module, we could do a remote check if there
>>>>>>>> already is a module by that name.
>>>>>>>> Users would also be kept from editing a stable module and by
>>>>>>>> this creating their own bastard modules that waste everybody's
>>>>>>>> time.
>>>>>>>> For releasing, this approach would also make things easier. You
>>>>>>>> could keep the SQL for a module within the file system, and
>>>>>>>> construct the SQL data dump with a build process.
>>>>>>>> I would like to see this happen this year. Mapbender needs to
>>>>>>>> change, things are growing to be more and more complex, yet
>>>>>>>> there is no infrastructure. We need less overhead, I don't want
>>>>>>>> to see Mapbender dead as a dodo.
>>>>>>>> Maybe we can discuss this face-to-face at FOSSGIS, but certainly
>>>>>>>> up front here.
>>>>>>>> _______________________________________________
>>>>>>>> Mapbender_dev mailing list
>>>>>>>> Mapbender_dev at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
More information about the Mapbender_dev mailing list
