[Mapbender-dev] motion: change file system layout
Samson, Marko Marko.Samson at wald-und-holz.nrw.de
Tue Jul 8 03:07:29 EDT 2008
+1 to the new filesystem structure.
And I like the additions of Melchior.
Viele Grüße,
Marko Samson
Marko Samson
Landesbetrieb Wald und Holz NRW
GIS-Anwendungsentwicklung
Referat I-5
Albrecht-Thaer-Straße 34
48147 Münster
Tel.:   0251/91797-166(Montags)
        05771/913455(Freitags)
Mail: marko.samson at wald-und-holz.nrw.de
> -----Original Message-----
> From: mapbender_dev-bounces at lists.osgeo.org
> [mailto:mapbender_dev-bounces at lists.osgeo.org] On Behalf Of
> Melchior Moos
> Sent: Monday, July 07, 2008 9:25 PM
> To: Mapbender Developer List
> Subject: Re: [Mapbender-dev] motion: change file system layout
> +1 I like the idea of a more structured filesystem.
> Why not add a plugin/  directory which has the same function
> as the mod directory but contains all modules the are not
> shipped with mapbenders standard installation? This would
> lead (in theory) to a clear division between customations and
> core code. This would be the place where the <project
> name>_<module name> modules would be.
> Christoph Baudson schrieb:
> > As most of Mapbender's recent security issues stem from files being
> > unnecessarily in the http folder, I think we should move as
> many files
> > as possible out of that directory. Only files which are
> really loaded
> > via http should remain there.
> > <motion>
> > I motion to
> > - move the PHP classes from /http/classes to /lib (and remove the
> > prefix "class_"). We can keep wrappers for the sake of backwards
> > compatibility (an old class file would only include a new
> class file).
> > - move the external libraries from /http/extensions to /ext
> > - create a folder /mod which holds a folder for each module
> (example:
> > /mod/mapframe1). Move files from /http/php and /http/javascripts to
> > these folders
> > in Mapbender 2.6 (est. release date Sep 15, 2008) </motion>
> > I already have a working experimental version in
> > /branches/testbaudson_dev.
> > The rest will remain untouched now, but will be moved to the new
> > folders later on (there is no need for http/frames, http/html,
> > http/include, http/print). I'm not sure how to deal with
> > http/javascripts and http/php, maybe we should have a
> http/mod folder
> > as well? I'm also not sure about /http/sld.
> > This approach also helps to
> > - isolate modules from the core
> > - optimize the core
> > - remove deprecated modules
> > - exchange modules
> > For customizations, we recommended to add a folder /http/x_<project
> > name> in the past. This folder could be replaced by folders
> > mod/<project name>_<module name>. This would help us to integrate
> > modules developed for specific scenarios into the Mapbender generic
> > development, and also to update overwhelmingly customized
> Mapbenders.
> > Sustainability is the keyword.
> > Christoph
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
More information about the Mapbender_dev mailing list
