[Mapbender-dev] Discussion: Character sets (client encoding)
Michael Schulz mschulz at webgis.de
Wed Jul 16 12:07:06 EDT 2008
>> If you define a default character set in apache (AddDefaultCharset)
>> this overrides all settings set via meta-tags, because apache settings
>> are in the http-header.
> I meant explicitly sending http headers in PHP. Is this overridden by
> Apache?
Ok - not sure, but I think this directive only adds a charset header
entry when none is specified beforehand. So it should be ok, but I'm
not an absolut apache expert - we'll probably have to check that.
Michael
> Christoph
>> Cheers, Michael
>>>> Just playing devil's advocat, I think we'll eliminate a lot of
>>>> problmes with that.
>>>> Cheers, Michael
>>> Christoph
>>>> 2008/7/16 Christoph Baudson <christoph.baudson at wheregroup.com>:
>>>>> Arnulf Christl schrieb:
>>>>>> Christoph Baudson wrote:
>>>>>>> This is a proposal to serve UTF-8 encoded HTML pages only. In my
>>>>>>> opinion
>>>>>>> there is no need to serve ISO-8859-1 pages.
>>>>>>> All character set conversions (when interacting with a database)
>>>>>>> could
>>>>>>> be
>>>>>>> done in PHP. So the architecture would change from
>>>>>>> client: ISO/UTF8
>>>>>>> server: UTF8
>>>>>>> database: ISO/UTF8
>>>>>>> to
>>>>>>> client: ISO/UTF8
>>>>>>> server: UTF8
>>>>>>> database: ISO/UTF8
>>>>>>> This will simplify things a lot and would make Mapbender less
>>>>>>> error-prone. If anyone has any reason why we should still serve ISO
>>>>>>> pages,
>>>>>>> please step up. I have no idea why we should.
>>>>>>> Thanks,
>>>>>>> Christoph
>>>>>> You confuse me, I cannot see the difference?
>>>>> neither do I.
>>>>> Here's what I meant
>>>>> client: UTF8
>>>>> server: UTF8
>>>>> database: ISO/UTF8
>>>>> Christoph
>>>>> nr: copy and paste for beginners
>>>>>> _______________________________________________
>>>>>> Mapbender_dev mailing list
>>>>>> Mapbender_dev at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
More information about the Mapbender_dev mailing list
