[Mapbender-dev] Ecnoding Troubles with Capabilites Documents
Michael Schulz
mschulz at webgis.de
Wed Jul 30 17:11:26 EDT 2008
Hi Arnulf,
I'll try that one, although i think it should already be included in rc5.
Well, I think the xml header should contain an encoding attribute and
xml_parser_create detects the input encoding and without encoding
parameter, sets the output encoding to: "In PHP 5.0.0 and 5.0.1, the
default output charset is ISO-8859-1, while in PHP 5.0.2 and upper is
UTF-8."
Cheers, Michael
2008/7/30 Arnulf Christl <arnulf.christl at wheregroup.com>:
> Does this fix it?
> http://trac.osgeo.org/mapbender/ticket/210
> Unfortunately I will be traveling the next days so that I don't whether I
> can test it myself.
> But in any case I don't get the logic because I cannot find any encoding
> tags anywhere in the Capabilities document - so how can anyone know at all?
> Cönfü߀d,
> Ärnülf.
> Michael Schulz wrote:
>> Hi,
>> just tried it with 2.5rc5.
>> mapbender + postgres: utf-8: still problems with the umlaute in
>> abstracts, titles, access constraint
>> Cheers, Michael
>> 2008/7/29 Christoph Baudson <christoph.baudson at wheregroup.com>:
>>> On Tue, July 29, 2008 6:32 pm, Arnulf Christl wrote:
>>>> High,
>>>> while still testing 2.5 rc4 I ran into trouble with Umlauts when
>>>> updating
>>>> "DNM 25" (see also my mail on users).
>>>> Is it worth following up or has this been resolved?
>>> Has been resolved.
>>> But I will recheck to make sure.
>>>> Regards, Arnulf.
>>>> _______________________________________________
>>>> Mapbender_dev mailing list
>>>> Mapbender_dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
More information about the Mapbender_dev
