[Mapbender-dev] Zoom to full extent
David Arndt arndt at geoinformation-planung.de
Tue May 6 08:59:23 EDT 2008
   Hi to all,
   I  enhanced the function "setExtent". So know it is possible to
zoom to full extent in other epsg then the first wms epsg. It is not
perfect, but it works.
   I enhanced the file map.js and there the function setExtent and the
file php/mod_zoomfull_projection.php (it only works at this time when
the mapbender database is postgresql with postgis extension enabled).
   I commit this new files to my branch darndt_dev, maybe we can put
in the next Mapbender.
   Regards, David.
geoinformation+planung
reichert+partner ingenieure
gölzstr. 22 72072 tübingen
fon: +49 (0)7071-407360
fax: +49 (0)7071-407361
info at geoinformation-planung.de
http://www.geoinformation-planung.de
Regionalplan Schwarzwald-Baar-Heuberg online: http://www.regionalplan-sbh.de
URL: http://lists.osgeo.org/pipermail/mapbender_dev/attachments/20080506/19477b02/attachment.html
More information about the Mapbender_dev mailing list
