[Mapbender-dev] GUI elements
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Mon May 19 12:10:05 EDT 2008
Hello devs,
 I second Christophs motion. Let's vote.
1.)  +1
2.) +1
3. ) I am not sure what this means in detail and how this "light"
version  could look like. need some more concreate description on this.
best regards astrid
Christoph Baudson schrieb:
> I think it's about time we make a decision
> <motion>
> I motion to
> 1) split "gui_element" into "element" and "application_element". This
> implies:
> - "element" is globally unique
> - "application_element" is unique only application-wide (like
> "gui_element" was)
you have to make sure that every element in table element has an entry
in table application_element.
e_src - should be part of application_element ( we have to get rid of
the iframes first)
> 2) add a "readonly" column to element. This implies:
> - You can't modify or delete "readonly" elements
> - You can only modify or delete your own elements
> - You can only modify "readonly" elements via "application_element"
> settings
> 3) The above changes have severe consequences. A lot of scripts are
> affected. My plan would be to set up a "light" version of Mapbender
> with a single admin and map application, and slowly incubate other
> modules into this version. Users could still work with the 2.5 series
> while incubation is in progress, but devs (including the GSoC
> students) could focus on the "light" version.
> </motion>
> Slimming down Mapbender would have a lot of effects. We could
> - have trouble with a lot of merging
> + get rid of deprecated files
> + reorganise the file system
> + add changes quickly (less files are affected)
> + make it easier for our GSoC students (they could work in a less
> complicated environment and have clearer tasks)
> + eliminate iframes
> + move SQL statements from dump to modules, and compile the dump with
> a build process (less error-prone)
> This is not a motion that you should nod off with a casual +1. Voting
> 0 is acceptable yet not helpful. Voting -1 implies you present
> alternatives or reasons why to stick to the current model.
> The only -1 I could think of are insufficient funding and backwards
> compatibility, yet I see more pros than cons. I see it as an
> investment that will pay off in the near future.
> Please vote +1, 0 or -1, don't be shy to use either option.
>>> In order to enhance the modular character of Mapbender, I propose to
>>> split the database table gui_element. The problem with the current
>>> table layout is, that there is no table for "element", just
>>> gui_element (From now on, whenever I speak of an "element" (as in
>>> "gui_element") I refer to it as a "module").
>> I think this is a severe change to the concept of application
>> elements. Formerly, copying an application element has been a copy
>> "by value", meaning a completely new set of element settings. You can
>> have two application elements with the same ID that are yet quite
>> different.
>> The new concept would imply copy "by reference", so altering a copied
>> element (without changing the id) would result in changing the
>> original as well. However, this would only be the case for the
>> element settings, and not the gui_element settings.
>> An example for the new "by reference" logic: There is an element
>> called "back". You copy it and modify only its "top" and "left"
>> settings. No problem with the original, as "top" and "left" are both
>> gui_element settings. Now let's change "HTML-TAG": This would change
>> the original, as it is an element setting (and not a gui_element
>> setting).
>> Now let's assume the element back was tagged "read-only". If you
>> would copy the element, you were to choose if you wanted to use the
>> original module (and ONLY alter gui_element settings like "top", copy
>> "by reference"), or if you wanted to create a new module based on the
>> original, with a new ID (and so being able to edit the element
>> settings like "HTML-TAG" as well, copy "by value").
>> For read-only elements, "by reference" could be the default copy
>> option, for other elements "by value".
>> An important issue are element vars. Now we only have
>> gui_element_vars. Do we still need them? Or is element_var
>> sufficient? I guess so. Because by altering element vars, you alter
>> the element itself.
>> The new database structure could look sth like this, let's discuss it
>> because I'm not 100% sure about some fields:
>> element:
>> e_id
>> e_comment
>> e_element
>> e_src (? - for images it would be better suited in
>> application_element, but for iframes :-/)
>> e_attributes
>> e_content
>> e_closetag
>> e_js_file
>> e_mb_mod
>> e_target
>> e_requires
>> e_url
>> e_readonly (THIS WOULD BE NEW!)
>> application_element (fka gui_element):
>> fkey_gui_id
>> e_public
>> e_pos
>> e_title
>> e_left
>> e_top
>> e_width
>> e_height
>> e_z_index
>> e_more_styles
>> element_vars (fka gui_element_vars):
>> fkey_e_id
>> var_name
>> var_value
>> context
>> var_type
>> I guess what I really want to say is that the gui_element_id is not
>> sufficient, we need element_ids for real control over the modules in
>> Mapbender. Class dismissed...anyone still awake? If yes, please comment.
>> Christoph
>>> So if you have to change a module, the changes do not propagate
>>> throughout Mapbender. You have to edit the settings in every GUI
>>> manually, it is harder to track module changes.
>>> Currently it's not possible to set a version number on a module. So
>>> you also do not know the compatibility status of a module. Some only
>>> work with specific versions, for example "set_locale" will require
>>> Mapbender 2.5, it should not be possible to load it in an older
>>> Mapbender.
>>> We need a centralised spot for keeping modules. Like an Eclipse
>>> update: You open your admin GUI and get a message about new
>>> available modules. Currently, you can only copy a GUI element from
>>> another GUI. Imagine, Mapbender could load it from mapbender.org. We
>>> would have enormous quality control over the modules in distributions.
>>> Another problem is module IDs, the same module can have two IDs in
>>> two separate GUIs. IDs should be unique at all the time. If a user
>>> created a new module, we could do a remote check if there already is
>>> a module by that name.
>>> Users would also be kept from editing a stable module and by this
>>> creating their own bastard modules that waste everybody's time.
>>> For releasing, this approach would also make things easier. You
>>> could keep the SQL for a module within the file system, and
>>> construct the SQL data dump with a build process.
>>> I would like to see this happen this year. Mapbender needs to
>>> change, things are growing to be more and more complex, yet there is
>>> no infrastructure. We need less overhead, I don't want to see
>>> Mapbender dead as a dodo.
>>> Maybe we can discuss this face-to-face at FOSSGIS, but certainly up
>>> front here.
>>> Mapbender_dev mailing list
>>> Mapbender_dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Mit freundlichen Grüßen
Astrid Emde
 Astrid Emde
 WhereGroup GmbH & Co.KG
 Siemensstraße 8
 53121 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 19
 Fax: +49(0)228 90 90 38 - 11
 www.wheregroup.com
 Amtsgericht Bonn, HRA 6788
 Komplementärin:
 WhereGroup Verwaltungs GmbH
 vertreten durch:
 Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
