[Mapbender-dev] Relation map object / wms object
Michael Schulz mschulz at webgis.de
Wed May 28 04:08:13 EDT 2008
Hi Christoph,
> I believe the administration tool does not have to be altered. Maybe I have
> to explain the background of my previous post: I'm working on web map
> context documents, which store the layers of the client in an XML document.
> When I'm representing both map frames (plus their layer settings) in the WMC
> document, I have no way of finding out the layer settings of the overview.
> The default settings are overwritten by changes made to the main map.
> Example: Assume a WMS is available in both overview and the main map. Then
> hide layers of that WMS via the treeGDE module.
Just to be curious, does the wmc spec have an option to store
information about an overview? I thought this is merely a flat list of
layers ...
Although you could put together a context collection with one wmc for
each mapobject. In that case you are right, wms setting changes
shouldn't cross map object scopes.
> Other solutions could be discussed, like
> * reload the default settings from the database
> * always show all layers of the overview WMS
For me, a wmc makes sense if it stores the current layer settings, not
some initial default, but presumably you have a special focus.
> but both solutions don't seem elegant to me, especially if you imagine
> having 7 maps and 3 overviews in one applications.
wow, i'd like to see that one ... ;-)
Michael
> I believe when Mapbender had been designed it was not intended to ever do
> sth. with the overview window after its instantiation, so then it made
> perfect sense. Now, we need more.
>> Cheers, Michael
>>> Please enlighten me if you have an explanation why the current solution
>>> is
>>> superior.
>>> Christoph
>>> _______________________________________
>>> W h e r e G r o u p GmbH & Co. KG
>>> Siemensstraße 8
>>> 53121 Bonn
>>> Germany
>>> Christoph Baudson
>>> Anwendungsentwickler
>>> Fon: +49 (0)228 / 90 90 38 - 15
>>> Fax: +49 (0)228 / 90 90 38 - 11
>>> christoph.baudson at wheregroup.com
>>> www.wheregroup.com
>>> Amtsgericht Bonn, HRA 6788
>>> Komplementärin:
>>> WhereGroup Verwaltungs GmbH
>>> vertreten durch:
>>> Arnulf Christl, Olaf Knopp, Peter Stamm
>>> Mapbender_dev mailing list
>>> Mapbender_dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
> Siemensstraße 8
> 53121 Bonn
> Germany
> Christoph Baudson
> www.wheregroup.com
> Komplementärin:
> vertreten durch:
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
More information about the Mapbender_dev mailing list
