[Mapbender-dev] Bugs in Mapbender 2.5 - Preparations for Mapbender 2.5.1
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Thu Nov 6 01:29:23 EST 2008
Hello list,
some of you already installed and use Mapbender 2.5. This version is a big
milestone.
Some bugs in this version were found and reported via the mailing-list or
mapbender-trac.
Have a look at the report "Known bugs in Mapbender 2.5":
  http://trac.osgeo.org/mapbender/report/37
If you discover more bugs for version 2.5, please report them too.
Please use the issue Tracker:
Trac is generally a good idea when experiencing a bug. The developer list is
informed instantly after you reported the issue. In order to use the bug
tracker, please register here
    http://www.mapbender.org/Trac#Register
You also can send a mail to the Mailing list
     mapbender_users at lists.osgeo.org
With your bug-reports we can work on Mapbender Version 2.5.1 which will
contain bug-fixes.
Best regards
Astrid Emde
More information about the Mapbender_dev mailing list
