[Mapbender-dev] WFS 1.1 design phase
Christoph Baudson christoph.baudson at wheregroup.com
Fri Nov 28 09:50:01 EST 2008
Currently I'm thinking about how to redesign some Mapbender PHP classes
in order to support WFS 1.1.0.
We are having a single class for a WFS. Its attributes are set by
methods like
createObjFromXML (the data is taken from a capabilities document) or
createObjFromDB (the data is already stored in Mapbender).
Of course, a capabilities document of version 1.1.0 different from a
1.0.0 document. So I have to enhance the current static model into a
more dynamic one.
We should have an abstract WFS class (maybe even an abstract OWS class),
and then let WFS_1_1 and WFS_1_0 inherit from WFS.
In order to keep most of the code intact, I wanted to avoid sth. like
$wfs = new WFS_1_1();
$wfs = new WFS_1_0();
so I was thinking about using a factory method approach.
http://en.wikipedia.org/wiki/Factory_method_pattern
A WFS factory would create WFS objects, we would not have to create them
ourselves. A WFS factory could have the methods mentioned above,
createObjFromXML and
createObjFromDB,
which would return either a WFS 1.1.0 or a WFS 1.0.0 object. The current
class wfs could be rewritten to be this factory. By this we could at
least keep some code intact.
I sketched the classes here
http://www.mapbender.org/Talk:WFS_1.1
Let's discuss and feel free to edit the wiki page.
Christoph
Where2B-Konferenz
Die Geo-IT Konferenz der WhereGroup
vom 9.-10. Dezember 2008 in Bonn
Web: www.where2b-conference.com
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
