[Mapbender-dev] Re: wfs gazetteer with umn mapserver wfs
Marc Manns marcmanns at t-online.de
Wed Aug 5 12:33:38 EDT 2009
Hi mandsch, Christoph and Michael :-),
i 've tested some  mapserver WFS  with the 2.6 branch.
I have to say that the gazetter module works very fine now.
I only got some troubles with the new jquery tablesorter module.
My error was caused by a misconfiguration with the output position numbers
which you can define in mod_wfs_edit.php.
If you don't set the columns to a correct order(without a gap),
the tablesorter module will not display any dataset that the WFS delivered.
Very cool feature,
now i can change over most of my WFS's to mapserver!! :-)
cheers marc
Michael Schulz schrieb:
> Hi Christoph,
> yes, I also agree, that this is a more generic approach and I'd be
> willing to integrate that into 2.6 branch. Although I'd be happy to
> have someone with strong-WFS background check this approach.
> Cheers, Michael
> 2009/7/29 Christoph Baudson <christoph.baudson at wheregroup.com>:
>>> Hi Michael,  ;-)
>>> another approach would be to search with xpath for
>>> "gml:featureMember", and then feed the firstChild, which is always the
>>> featuretype to the featuretype parser ... sth. like that:
>>> $gmlFeatureMembers = $gmlDoc->xpath("//gml:featureMember");
>>> if (count($gmlFeatureMembers) > 0) {
>>>        foreach ($gmlFeatureMembers as $gmlFeatureMember) {
>>>                $gmlfeatureMember_dom =
>>> dom_import_simplexml($gmlFeatureMember);
>>>                $feature = new Feature();
>>>                $this->parseFeature($gmlfeatureMember_dom->firstChild,
>>> $feature, $wfsConf);
>>>                if (isset($feature->geometry)) {
>>>                        $gml->featureCollection->addFeature($feature);
>> This looks like a more generic approach...are you willing to integrate this
>> into the 2.6 branch?
>> But I guess we should consult mschulz first ;-)
>> Thanks for your help
>> Christoph
>>> Actually, I wondered why e.g. QGIS had no problems to load a UMN
>>> WFS... so that's the reason.
>>> Cheers, mandsch
>>> 2009/7/28 Michael Schulz <mschulz at webgis.de>:
>>>> Hi Devs,
>>>> after some detours and especially after some valuable hints from
>>>> Christoph on irc I came to this workaround, for the described problem,
>>>> when using UMN as WFS-Server and getting no results from WFS-Gazatteer
>>>> requests, because there is an obscure namespace problem with UMN-WFS
>>>> (it breaks down to: umn gives a featuretype name in the getcaps
>>>> without ns, this is stored in the mapbender db, when parsing
>>>> getfeature request, that stored value is used to go through the
>>>> getfeature result xml, that unfortunately now uses a namespace "ms:",
>>>> so mapbender code won't find any features).
>>>> My workaround is to ignore namespaces when searching for the result
>>>> features, by using the xpath function local-name(). This can be
>>>> applied in class_gml_factory around line 20, instead of:
>>>>  $gmlFeatureMembers = $gmlDoc->xpath("//" . $featureType->name);
>>>> you could write:
>>>>  $admin = new administration();
>>>>  $gmlFeatureMembers = $gmlDoc->xpath("//*[local-name()='".
>>>> $admin->sepNameSpace($featureType->name)."']" );
>>>> This ignores the namespace, but certainly leaves the xml untouched.
>>>> I've tested it with UMN and Geoserver. If someone wants to give it a
>>>> try, I'll be happy for any feedback.
>>>> Cheers, Michael
>>>> 2009/7/14 Michael Schulz <mschulz at webgis.de>:
>>>>> Hi,
>>>>> I have a strange problem when using umn mapserver as a wfs-server for
>>>>> a gazetteer search. The problem is that the featuretype is announced
>>>>> in get getCaps as
>>>>> <Name>meinFeatureType</Name>.
>>>>>  When actually searching and issueing the getfeature request, the
>>>>> result is returned with featuremembers with the default ms namespace:
>>>>> <gml:featureMember><ms:meinFeatureType
>>>>> fid="meinFeatureType.007">...</gml:featureMember>.
>>>>> The problem is now that in the gml classes, the returned gml is
>>>>> accessed with the xpath function searching for the featuretype name as
>>>>> recieved from the getCapabilities response and since this name has no
>>>>> namespace it won't find the featuremembers...
>>>>> Is this a mapserver wfs misconfiguration on my side (i tried with
>>>>> wms_namespace_prefix ...) or a mapserver wfs bug or a mapbender bug?
>>>>> When using geoserver the featuretype namespace is also returned in the
>>>>> getcapabilities response.
>>>>> Thanks for your hints ... Michael
>>>>> Aufwind durch Wissen!
>>>>> Qualifizierte Open Source Schulungen bei der
>>>>> http://www.foss-akademie.de/
>>>>> Michael Schulz
>>>>> in medias res
>>>>> Gesellschaft für Informationstechnologie mbH
>>>>> +++ Bitte beachten Sie unsere neue Adresse und Durchwahl +++
>>>>> Schwimmbadstraße 2
>>>>> D-79100  Freiburg i. Br.
>>>>> Tel:  +49 (0)761 705798-102
>>>>> Tel:  +49 (0)761 705798-0
>>>>> Fax: +49 (0)761 705798-09
>>>>> http://www.webgis.de / http://www.zopecms.de
>>>>> Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
>>>>> Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
>>>> Michael Schulz
>>>> in medias res
>>>> Schwimmbadstraße 2
>> Qualifizierte OpenSource-Schulungen
>> bei der www.foss-academy.eu
>> _______________________________________
>> W h e r e G r o u p GmbH & Co. KG
>> Siemensstraße 8
>> 53121 Bonn
>> Germany
>> Christoph Baudson
>> Anwendungsentwickler
>> Fon: +49 (0)228 / 90 90 38 - 15
>> Fax: +49 (0)228 / 90 90 38 - 11
>> www.wheregroup.com
>> Amtsgericht Bonn, HRA 6788
>> Komplementärin:
>> WhereGroup Verwaltungs GmbH
>> vertreten durch:
>> Olaf Knopp, Peter Stamm
>> Mapbender_dev mailing list
>> Mapbender_dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
More information about the Mapbender_dev mailing list
