[Mapbender-dev] CSS file inclusion
Christoph Baudson christoph.baudson at wheregroup.com
Thu Aug 13 04:47:08 EDT 2009
Hello,
I wondered why all modules have to add their CSS files to the body
element. This is not modular. I checked index.php and found that the SQL
that queries the file/css entries from gui_element_vars is restricted to
the element "body". I think that is not sensible.
I recommend to change this to all non-iframe application elements. My
SQL would read sth like this
SELECT DISTINCT var_value AS var_value FROM gui_element AS ge,
gui_element_vars AS gevWHERE ge.e_id = gev.fkey_e_id AND ge.fkey_gui_id
= gev.fkey_gui_id AND ge.e_id = gev.fkey_e_id AND ge.e_element <>
'iframe' AND gev.fkey_gui_id = $1 AND gev.var_type='file/css'
Then each module could come with its own CSS settings. In the past
missing CSS files have been a major source for errors, mostly because
people didn't add them to body (popup comes to mind).
Let's discuss if this is a good approach. We could also do this for
text/css.
Christoph
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
