[Mapbender-dev] [Mapbender] #508: PostgreSQL 8.4 does not work with pgsql_data_2.5.sql
Mapbender mapbender_dev at lists.osgeo.org
Thu Aug 13 11:24:54 EDT 2009
 Reporter:  tbaschetti      |       Owner:  dev
     Type:  defect          |      Status:  new
 Priority:  critical        |   Milestone:  2.6 release
Component:  database        |     Version:  2.6 rc1
 Keywords:  PostgreSQL 8.4  |
 In PostgreSQL internal structure has changed, pg_catalog.pg_class does no
 longer contain reltriggers::smallint but has relhastrigger::boolean, so
 the import-script pgsql_data_2.5.sql fails at:
  UPDATE pg_catalog.pg_class SET reltriggers = 0;
 many subsequent inserts also fail as a consequence, resulting in an
 unusable database.
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/508>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
