[Mapbender-dev] PostgreSQL 8.4 problems
Michael Schulz
mschulz at webgis.de
Thu Aug 13 13:13:25 EDT 2009
Hi Thomas,
this is needed for the import of the wms, and layer data i think,
because these tables habe prim keys and constraints to foreign keys.
this constraint checking is basically disabled before inserting the
data and the again activated.
Have a look in the wiki for the howto compile a mapbender release ...
or similar.
I think so too, that this should be fixed for 2.6. I can also have a
look at it tomorrow.
Cheers, Michael
2009/8/13 Thomas Baschetti <info at thomas-baschetti.de>:
> Hi,
> apperently PostgreSQL 8.4 can't be used to create a new Mapbender-database,
> see http://trac.osgeo.org/mapbender/ticket/508
> for details.
> My Question: How is this dump created? If i use pgadmin3 or pg_dump
> directly, there is no such command as "update pg_catalog.pg_class ...".
> Why is this needed?
> I think we should fix this in 2.6.
> Bye
> Thomas
> Thomas Baschetti - Systemanalyse Geographische Informationssysteme
> Hakenstraße 8D
> 49074 Osnabrück
> Tel: 0541 25 91 90 | mobil 01577 189 25 91
> E-Mail: info at thomas-baschetti.de
> www.thomas-baschetti.de
> Ust-IdNr.: DE264355072
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Aufwind durch Wissen!
Qualifizierte Open Source Schulungen bei der
http://www.foss-akademie.de/
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
+++ Bitte beachten Sie unsere neue Adresse und Durchwahl +++
Schwimmbadstraße 2
D-79100 Freiburg i. Br.
Tel: +49 (0)761 705798-102
Tel: +49 (0)761 705798-0
Fax: +49 (0)761 705798-09
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_dev
