[Mapbender-dev] jQuery UI effects
Christoph Baudson (Wheregroup) christoph.baudson at wheregroup.com
Tue Dec 22 10:57:45 EST 2009
Hello,
today I have added an element that loads multiple jQuery UI effects [1].
Just set the element vars of the effects you want to use to 1. You can
use the effect like this [2].
I have added the "transfer" effect to the saveWMC module. When you close
the saveWMC dialog, you will notice an animation that traces the popup
back to the button that created it. I think it adds to the look and feel.
Christoph
[1]
https://svn.osgeo.org/mapbender/trunk/mapbender/documents/api_js/files/javascripts/jq_ui_effects-php.html
[2] http://jqueryui.com/demos/effect/
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
