[Mapbender-dev] install script for windows? - links to cmd / bat help pages
Astrid Emde astrid.emde at wheregroup.com
Wed Jul 1 12:44:48 EDT 2009
Hello Thomas,
this is very cool.
On Wed, July 1, 2009 6:24 pm, Thomas Baschetti wrote:
> Hi,
> ok, i've finished the first version and commited it (2.6).
> What i left out:
> - setting permissions (would highly depend on used webserver (apache,
iis...)
> - compiling .po files as msgfmt isn't installed on windows
msgfmt.exe should be installed on windows too. This tools comes with the
installation of poedit. You only have to aff the path to msgfmt to the
PATH  variable.
Please have a look at:
http://www.mapbender.org/Gettext#Utility_programms
It would be cool if this would be added to the script aswell.
> Testers are welcome.
This can be difficult as noone uses windows ;)
I have a windows system where I can test your scripts.I will give feedback
soon.
Thanks for your job
Astrid
> Ciao
> Thomas
> Astrid Emde schrieb:
>> Hello Thomas,
>> this is great. I also thought about you. We will give you the ok, when the
>> script is ready.
>> see you astrid
>> On Wed, June 24, 2009 8:03 pm, Thomas Baschetti wrote:
>>> Hi,
>>> i have a running windows-installation, so i can do it next week, if
there is nobody else.
>>> Bye
>>> Thomas
>>> David Arndt schrieb:
>>>> Hello List,
>>>> it is a  problem for me. I don't have a running Windows-Installation.
Maybe
>>>> there is someone who can provide a script for windows.
>>>> Regards, David.
>>>> Am Mittwoch, 24. Juni 2009 18:30:02 schrieb Astrid Emde:
>>>>> Hello David,
>>>>> if we want to provide an install.bat for windows too, maybe the
following
>>>>> links can help us with this.
>>>>> http://www.libe.net/themen/BATch-Befehle.php
>>>>> http://www.script-example.com/themen/cmd_Batch_Befehle.php
>>>>> http://de.wikipedia.org/wiki/Windows_Batch
>>>>> astrid
>>>>> _______________________________________________
>>> Mapbender_dev mailing list
>>> Mapbender_dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Mit freundlichen Grüßen
Astrid Emde
Treffen Sie uns auf der AGIT 2009, vom 8.-10. Juli in Salzburg!
Lassen Sie sich an Stand Nr. 30 über neue Entwicklungen
im Bereich WebGIS informieren!
www.agit.at
  Astrid Emde
  WhereGroup GmbH & Co.KG
  Siemensstraße 8
  D-53121 Bonn
  Fon: +49(0)228 90 90 38 - 19
  Fax: +49(0)228 90 90 38 - 11
  http://www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
