[Mapbender-dev] Re: Catalog Schema and Storing Op values
Armin Retterath armin.retterath at lvermgeo.rlp.de
Thu Jul 9 10:44:45 EDT 2009
hi mifam,
i am sorry, we need the post urls too, cause the specification demands post
for  GetRecords and DescribeRecords. many catalogues would only implement
this minimal demands. 'get' is in this two cases only nice too have.
please see http://www.mapbender.org/CSW_Requirements point 8.
cheers
armin
Am Donnerstag 09 Juli 2009 07:52:39 schrieb Mifan Careem:
> Hi List,
> I've current solved the problem by storing the GET values of the
> operations (e.g getrecords) in the main catalog schema itself. I am
> currently not storing the other parameter values of the operations - if
> this is needed, I can handle this later on, but since currently I just
> need the GET URLs, I'll concentrate on this.
> Let me know if there are any suggestions.
> Thanks
> Mifan
> On Tue, 2009-07-07 at 16:05 +0530, Mifan Careem wrote:
> > Dear list,
> > My current schema to store a catalog object is here:
> > http://www.mapbender.org/CSW_report_week_3
> > I currently provide an Admin function to 'Load a Catalog'. In this, I
> > need to store Operation[1] values from the OperationsMetadata section of
> > the Catalog's GetCapabilities[2] document. What would the best way be to
> > store these operations sections (getrecords,describerecords etc.),
> > considering that I have to make use of the GET/POST values often to make
> > a CSW search?
> > Currently, I thought of this:
> > - Store normal catalog information in the cat table
> > - store Parameter names and values of the Operations in a seperate
> > table, like this:
> > INSERT INTO cat_op_conf(id,op_name,param_name,param_value) VALUES
> > (2,'getrecords',http_get,http://www.geodata.alterra.nl/excat/csw);
> > (2,'getrecords','typename','csw:Record');
> > etc.
> > Any suggestions?
> > [1]: <ows:Operation name="DescribeRecord">
> > <ows:DCP>
> > <ows:HTTP>
> > <ows:Get xlink:href="http://www.geodata.alterra.nl/excat/csw"/>
> > <ows:Post xlink:href="http://www.geodata.alterra.nl/excat/csw"/>
> > </ows:HTTP>
> > </ows:DCP>
> > <ows:Parameter name="TypeName">
> > <ows:Value>csw:Record</ows:Value>
> > </ows:Parameter>
> > <ows:Parameter name="OutputFormat">
> > <ows:Value>application/xml</ows:Value>
> > </ows:Parameter>
> > <ows:Parameter name="SchemaLanguage">
> > <ows:Value>XMLSCHEMA</ows:Value>
> > <ows:Value>http://www.w3.org/XML/Schema</ows:Value>
> > </ows:Parameter>
> > </ows:Operation>
> > [2]:
> > http://www.geodata.alterra.nl/excat/csw?request=GetCapabilities&service=C
> >SW
> > Thanks
> > Mifan
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Im Auftrag
Armin Retterath
Kompetenz- und Geschäftsstelle Geodateninfrastruktur Rheinland-Pfalz
beim
Landesamt für Vermessung und Geobasisinformation Rheinland-Pfalz
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
Telefon 0261/492-466
Telefax 0261/492-492
http://www.geoportal.rlp.de
More information about the Mapbender_dev mailing list
