[Mapbender-dev] Public access to Mapbender
Christoph Baudson christoph.baudson at wheregroup.com
Mon Jul 13 04:13:59 EDT 2009
This problem should be solved before Mapbender 2.7 is released. We
should think about a solution in the next weeks, so we have time to
implement a solution before the feature freeze.
Fortunately, Armin has added his valuable thoughts on this topic [1]. He
is the administrator of a large Mapbender installation
(www.geoportal.rlp.de) and by this has a lot of experience with the
topic. I urge you to read it and discuss the issues here.
I'll also put it on the agenda of the IRC meeting today.
Thanks
Christoph
[1] http://www.mapbender.org/Public_User
Christoph Baudson schrieb:
> Astrid Emde schrieb:
>> Hello Christoph,
>>> In the past I have experienced a lot of trouble with demo
>>> applications that are made public via a user like "demo" and a
>>> similar password.
>>> The most annoying problem is, that the account can be disabled by
>>> trying to log in several times with a wrong password. How about this
>>> workaround: if the login_count is set to -1 by the owner, the
>>> login_count would never be incremented in the first place, thus
>>> never disabling the account. This would be a quick fix.
>> I favorite this quite easy solution.
>>> A more generic solution could include a new column in mb_user, with
>>> a "public" flag. If this flag was set, you could log in no matter
>>> what password you supplied (I think it's counter-intuitive to have a
>>> password for a public user). Maybe Mapbender should be delivered
>>> with a default public user, to encourage the usage.
>>> A less significant problem is, that you do not know if there are any
>>> "public" users in a Mapbender installation. You always have to try
>>> "demo", "guest", "gast", "anonymous" etc. if there is no
>>> documentation. Maybe the Mapbender server should have this as an API
>>> function, or we could include it in the portal site.
>>> We should think of a solution, as most installations offer this kind
>>> of public access.
>> This does not sound as a good solution for me. The administrators of
>> mapbender should decide by themself whether they want to offer a
>> public user or not.
> This was an additional suggestion. The main idea is to flag "public"
> users by a column in the mb_user table.
> We do not have to include a default public user, although in my
> opinion this would be more intuitive. The problem would be
> updates...some installations will already have a user with the name we
> would come up with ;-)
>>> Christoph
>> Best regards astrid
>> Mapbender_dev mailing list
>> Mapbender_dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Treffen Sie uns auf der AGIT 2009, vom 8.-10. Juli in Salzburg!
Lassen Sie sich an Stand Nr. 30 über neue Entwicklungen
im Bereich WebGIS informieren!
www.agit.at
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
