[Mapbender-dev] Re: Catalog Schema and Storing Op values
Armin Retterath armin.retterath at lvermgeo.rlp.de
Wed Jul 15 11:51:34 EDT 2009
hello mifan, list,
i think this is a good idea. interesting would be the update process of a
catalogue service ;-). i don't think that we would get more than 10 different
cats in one gui - therefor it will be no problem to pull the used urls aout
off the database. our next problem will be to define a schema for storing and
viewing the requested resources. we had the idea to put them in the temp
folder as json files. the client can read them by session_id. maybe we can
discuss this tomorrow.
regards armin
Am Mittwoch 15 Juli 2009 15:08:13 schrieb Mifan Careem:
> Hi Armin, List,
> Would a schema like this be helpful to store the operational values in
> the get_capabilities document?
> cat_op_conf (fkey_cat_id,param_type,param_name,param_value)
> Following would be sample inserts:
> INSERT INTO cat_op_conf(fkey_cat_id,param_type,param_name,param_value)
> VALUES (1,get_capabilities,get,http://something/...);
> VALUES (1,get_capabilities,post_soap,http://something/...);
> VALUES (1,get_capabilities,post_xml,http://something/...);
> VALUES (1,get_records,get,http://something/...);
> VALUES (3,get_capabilities,post,http://something/...);
> This would be more efficient than storing a part-XML structure, and we
> can handle the various get,post and soap values - and it would be more
> efficient to retrieve them.
> Thoughts are appreciated.
> Regards
> Mifan
> On Fri, 2009-07-10 at 09:31 +0200, Armin Retterath wrote:
> > good morning mifan,
> > the schema i described in part 7 was only a hint ;-). i know that there
> > is a problem when there are the two bindings http and soap. there are
> > many urls to handle with. maybe we can split the soap binding from the
> > http and create a new table 'cat_op_soap' for it? maybe the schema would
> > be something  like : fkey_cat_id, cat_op_getcapabilities, ...
> > please think about it and check it for usability - in future we have to
> > integrate the soap binding for wms and wfs in a similar manner.
> > the second table will make the updates a little bit more complicated -
> > but this is a problem of the standards and we must handle it on an easy
> > way. an other possibility is to store the whole xml part:
> > <ows:Operation name="GetCapabilities">
> > <ows:DCP>
> > <ows:HTTP>
> > <ows:Get xlink:href="http://www.portalu.de:80/csw202"/>
> > <ows:Post xlink:href="http://www.portalu.de:80/csw202">
> > <ows:Constraint name="PostEncoding">
> > <ows:Value>SOAP</ows:Value>
> > </ows:Constraint>
> > </ows:Post>
> > <ows:Value>XML</ows:Value>
> > </ows:Constraint>
> > </ows:Post>
> > </ows:HTTP>
> > </ows:DCP>
> > </ows:Operation>
> > in one column. the problem will be, that we have to parse the information
> > every time we need them. i would prefer the storing in a relational
> > structure. but i think you must check it.
> > if have further questions - please ask.
> > cheers
> > armin
> > Am Freitag 10 Juli 2009 06:13:08 schrieben Sie:
> > > Hi Armin,
> > > On Thu, 2009-07-09 at 16:44 +0200, Armin Retterath wrote:
> > > > i am sorry, we need the post urls too, cause the specification
> > > > demands post for  GetRecords and DescribeRecords.
> > > Ok - no worries - will handle the post values as well - is there a
> > > chance the SOAP values should be stored as well?. I'm just wondering
> > > whether it is possible to store both values in the schema described in
> > > Section 7 of the wiki? Or should I have another field to capture the
> > > post values?
> > > Anyways, I will add this in somewhere.
> > > Thanks
> > > Mifan
> > > > many catalogues would only implement
> > > > this minimal demands. 'get' is in this two cases only nice too have.
> > > > please see http://www.mapbender.org/CSW_Requirements point 8.
> > > > cheers
> > > > armin
> > > > Am Donnerstag 09 Juli 2009 07:52:39 schrieb Mifan Careem:
> > > > > Hi List,
> > > > > I've current solved the problem by storing the GET values of the
> > > > > operations (e.g getrecords) in the main catalog schema itself. I am
> > > > > currently not storing the other parameter values of the operations
> > > > > - if this is needed, I can handle this later on, but since
> > > > > currently I just need the GET URLs, I'll concentrate on this.
> > > > > Let me know if there are any suggestions.
> > > > > Thanks
> > > > > Mifan
> > > > > On Tue, 2009-07-07 at 16:05 +0530, Mifan Careem wrote:
> > > > > > Dear list,
> > > > > > My current schema to store a catalog object is here:
> > > > > > http://www.mapbender.org/CSW_report_week_3
> > > > > > I currently provide an Admin function to 'Load a Catalog'. In
> > > > > > this, I need to store Operation[1] values from the
> > > > > > OperationsMetadata section of the Catalog's GetCapabilities[2]
> > > > > > document. What would the best way be to store these operations
> > > > > > sections (getrecords,describerecords etc.), considering that I
> > > > > > have to make use of the GET/POST values often to make a CSW
> > > > > > search?
> > > > > > Currently, I thought of this:
> > > > > > - Store normal catalog information in the cat table
> > > > > > - store Parameter names and values of the Operations in a
> > > > > > seperate table, like this:
> > > > > > INSERT INTO cat_op_conf(id,op_name,param_name,param_value) VALUES
> > > > > > (2,'getrecords',http_get,http://www.geodata.alterra.nl/excat/csw)
> > > > > >; INSERT INTO cat_op_conf(id,op_name,param_name,param_value)
> > > > > > VALUES (2,'getrecords','typename','csw:Record');
> > > > > > etc.
> > > > > > Any suggestions?
> > > > > > [1]: <ows:Operation name="DescribeRecord">
> > > > > > <ows:DCP>
> > > > > > <ows:HTTP>
> > > > > > <ows:Get xlink:href="http://www.geodata.alterra.nl/excat/csw"/>
> > > > > > <ows:Post xlink:href="http://www.geodata.alterra.nl/excat/csw"/>
> > > > > > </ows:HTTP>
> > > > > > </ows:DCP>
> > > > > > <ows:Parameter name="TypeName">
> > > > > > <ows:Value>csw:Record</ows:Value>
> > > > > > </ows:Parameter>
> > > > > > <ows:Parameter name="OutputFormat">
> > > > > > <ows:Value>application/xml</ows:Value>
> > > > > > </ows:Parameter>
> > > > > > <ows:Parameter name="SchemaLanguage">
> > > > > > <ows:Value>XMLSCHEMA</ows:Value>
> > > > > > <ows:Value>http://www.w3.org/XML/Schema</ows:Value>
> > > > > > </ows:Parameter>
> > > > > > </ows:Operation>
> > > > > > [2]:
> > > > > > http://www.geodata.alterra.nl/excat/csw?request=GetCapabilities&s
> > > > > >ervi ce=C SW
> > > > > > Thanks
> > > > > > Mifan
> > > > > _______________________________________________
> > > > > Mapbender_dev mailing list
> > > > > Mapbender_dev at lists.osgeo.org
> > > > > http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Im Auftrag
Armin Retterath
Kompetenz- und Geschäftsstelle Geodateninfrastruktur Rheinland-Pfalz
beim
Landesamt für Vermessung und Geobasisinformation Rheinland-Pfalz
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
Telefon 0261/492-466
Telefax 0261/492-492
http://www.geoportal.rlp.de
More information about the Mapbender_dev mailing list
