[Mapbender-dev] motion: change attribute "extent" of map
Uli Rothstein (WhereGroup) uli.rothstein at wheregroup.com
Wed Jun 3 05:33:36 EDT 2009
Hello,
yes, great
+1
Uli
Christoph Baudson schrieb:
> Currently, this is a string containing four comma-separated coordinates.
> This is hard to use, whenever you want to perform an operation on the
> extent, you have to split the string and use parseFloat. There is also
> no way to register an event with the setting of the extent, because it's
> not a function.
> At the development sprint in Hannover Peter and I discussed the
> implementation of a restricted extent. For this, we concluded, using the
> Extent object as attribute (and no longer the string) would be
> necessary. I am changing this in trunk, if this motion passes. The
> changes would include
> (1) The extent attribute is currently *set* by
> map.extent = "a,b,c,d";
> The new version would use this syntax
> map.extent = new Extent(a,b,c,d);
> (2) The extent attribute is currently *read* by
> map.extent
> which is a string "a,b,c,d". The new version would use this syntax
> map.extent.toString();
> and return the same string "a,b,c,d".
> All custom modules would have to use these changes as well, which will
> be important when updating. I'll only change the modules in Mapbender
> trunk.
> Please second this motion and vote.
> Christoph
Ulrich Rothstein
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 17
Fax: +49 (0)228 / 90 90 38 - 11
mailto:uli.rothstein at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
