[Mapbender-dev] Week 3
Karim Malhas karim at malhas.de
Sat Jun 13 16:08:38 EDT 2009
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA512
Dear List,
Since I am going to put parts of the code that I am producing into the
gui_elements table, I am not so sure of how to put this into svn.
For now I maintain a local repository that contains a HTML file that
represents what a "finished" gui could look like, and does not yet use
the gui_elemnts Table. That would kind be the "static" configuration
idea :-)
Should I just put this in svn and pull out each element later?
Take a look at [1]. My plan is to use each of the red-bordered areas as
an element (note that the listentries are dummies).
This way each of these can be added to an admin gui individually
Do you think that's a good idea?
This has the drawback that it's not possible to define subelements, as
far as I understand it.
Regards,
Karim
[1] http://karim.malhas.de/gsoc09/tmp/admin.xml
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.11 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org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=WRmI
-----END PGP SIGNATURE-----
More information about the Mapbender_dev mailing list
