[MOTION] Re: [Mapbender-dev] magic quotes
Arnulf Christl arnulf.christl at wheregroup.com
Mon Jun 29 11:16:48 EDT 2009
On Mon, June 15, 2009 10:53, Christoph Baudson wrote:
> Astrid Emde (WhereGroup) schrieb:
>> On Thu, February 26, 2009 11:51 am, Christoph Baudson wrote:
>>> Hello,
>>> Mapbender is not very decisive whether to use stripslashes on request
>>>  parameters or not. We seem to indecisive if we assume
>>> magic_quotes_gpc to be on or  off (it is on by default).
>>> I suggest we add something like this to globalSettings.php
>>> if (get_magic_quotes_gpc() === 1) { array_walk($_POST,
>>> 'stripslashes');
>>> array_walk($_GET, 'stripslashes'); }
>>> By this, all input would be properly prepared, and no stripslashing
>>> would have to occur.
>>> What do you think?
>>> Christoph
>> Hello Christoph,
>> this idea sounds reasonable to me.
>> astrid
> (I have just stumbled over this issue again, which resulted in another
> wasted hour. I should have made a motion the first time around.)
> I motion to add the code snippet
> if (get_magic_quotes_gpc() === 1) { array_walk($_POST, 'stripslashes');
> to globalSettings.php, so it will automatically be executed in every
> module. I volunteer to search for every occurence of stripslashes in
> Mapbender, and remove it where appropriate.
> (Maybe this is something that can be done in Bolsena.)
> Please second and vote.
Seconded by Arnulf
Vote: +1
Best regards,
Arnulf
> Christoph
>> Mapbender_dev mailing list
>> Mapbender_dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
> W h e r e G r o u p GmbH & Co. KG
> Siemensstraße 8
> 53121 Bonn
> Germany
> Christoph Baudson
> Anwendungsentwickler
> Fon: +49 (0)228 / 90 90 38 - 15
> Fax: +49 (0)228 / 90 90 38 - 11
> christoph.baudson at wheregroup.com www.wheregroup.com Amtsgericht Bonn, HRA
> 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch: Olaf Knopp, Peter Stamm
Arnulf Christl
http://www.wheregroup.com
More information about the Mapbender_dev mailing list
