[Mapbender-dev] [Mapbender] #423: WFS Configuration: Problems with German Umlaute
Mapbender mapbender_dev at lists.osgeo.org
Wed Mar 25 11:39:13 EDT 2009
 Reporter:  teac                              |       Owner:  dev
     Type:  defect                            |      Status:  new
 Priority:  major                             |   Milestone:  2.6 release
Component:  wfs                               |     Version:  2.6 rc1
 Keywords:  WFS German Umlaute encoding UTF8  |
 Start the GUI admin_en_services, Configure WMS:
 If a label-entry contains german Umlaute, the label is displayed
 incorrectly (e.g. when entering attribute-data while digitizing)
 If a SELECT-Box with german Umlaute is used in the HTML-Field in the WFS-
 Configuration, the problem also occurs. When I try to enter attribute-data
 using the SELECT-Box while digitizing, the predefined entries are
 displayed incorrectly.
 System:
 - Mapbender 2.6rc1 on a Windows XP System
 - Postgresql DB with UTF8 Encoding
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/423>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
