[Mapbender-dev] CSS files
Christoph Baudson (Wheregroup) christoph.baudson at wheregroup.com
Tue Nov 3 05:03:25 EST 2009
Currently, Mapbender only loads CSS files which are attached to the
body. This is still a left-over from the days when iframes were popular
in Mapbender.
It would be more convenient to be able to load CSS files with each
module, instead of having to add it to the body. This is a known error
source.
Of course, the best way would be to only use the classes of the jQuery
UI framework. But I think we should make this change soon and fix the
conflicts in the CSS files. I tested the change shortly, and I found
that print.css and addwms.css are most harmful.
Maybe a job for someone at the dev sprint?
Christoph
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
