[Mapbender-dev] [Mapbender] #553: resizeMapsize mode auto causes distorted map image
Mapbender mapbender_dev at lists.osgeo.org
Wed Nov 11 06:45:02 EST 2009
 Reporter:  mschulz         |       Owner:  dev
     Type:  defect          |      Status:  new
 Priority:  major           |   Milestone:  2.6.1
Component:  user interface  |     Version:  2.6 rc1
 Keywords:                  |
 When using the module resizeMapsize in mode "auto", then this will lead to
 a distorted or skewed map on startup, since the map is only resized but
 not repainted. Fix seems to be: set skipMapRequest to false by calling
 control with false, in mod_resize_mapsize.php line 123.
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/553>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
