[Mapbender-dev] [Mapbender] #544: Add FirePHP to Mapbender
Mapbender mapbender_dev at lists.osgeo.org
Thu Oct 15 09:25:33 EDT 2009
 Reporter:  christoph    |       Owner:  dev
     Type:  enhancement  |      Status:  new
 Priority:  minor        |   Milestone:  2.7 release
Component:  core         |     Version:
 Keywords:  debugging    |
 FirePHP is a useful tool for debugging, see http://www.firephp.org/
 You can, for example, log stuff in PHP and display it in Firebug. It is
 non-obtrusive, as it uses HTTP headers to transfer the data (no IE
 It is especially useful in scenarios where you have no access to your
 remote server: then FirePHP will re-route server side errors to Firebug.
 It is of course a potential security hazard, so it should be turned off in
 production use (is turned off by default).
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/544>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
