[Mapbender-dev] Demos online again at Telascience
Christoph Baudson (Wheregroup)
christoph.baudson at wheregroup.com
Wed Apr 7 08:47:12 EDT 2010
Karim Malhas schrieb:
> On Wed, Apr 07, 2010 at 01:56:15PM +0200, "Christoph Baudson (Wheregroup)" <christoph.baudson at wheregroup.com> wrote
>> Christoph Baudson (Wheregroup) schrieb:
>>> I just had to restart postgresql
>>> Christoph
>> happened again....what could cause this problem?
> What exactly is the problem ? Not being able to log in again?
> Last time the updatescript didn't close their postgres connections.
> Maybe something like that again ?
The problem is that you can't log in at Mapbender. Maybe it's just what
you are describing.
Telascience admins to the rescue!
Christoph
> Karim
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
