[Mapbender-dev] GSoC 2010 Project - RESTful API for Mapbender [RFC]
Astrid Emde astrid.emde at wheregroup.com
Tue Apr 27 03:00:18 EDT 2010
Hello Vikash,
welcome to the Mapbender project and a good Summer of Code for you.
All the best for your exams and see you after May 6th.
Astrid
On Mon, April 26, 2010 8:48 pm, Vikash Banjara wrote:
> Hi,
> Thanks to all of you.
> I am officially accepted for the GSoC 2010. I will work on "Restful API
> for Mapbender".
> P.S.: I will not be available before 6th May, because of exams at the
> university. I will start soon after the exams are over.
> Regards
> Vikash
> On Tue, Apr 6, 2010 at 5:45 PM, Vikash Banjara
> <vikashbanjara at gmail.com>wrote:
>> Seven,
>> Thanks for your suggestions. I have made proper changes to the
>> application. You can check out once again.
>> On Tue, Apr 6, 2010 at 4:14 PM, Seven (aka Arnulf)
>> <seven at arnulf.us>wrote:
>>> -----BEGIN PGP SIGNED MESSAGE-----
>>> Hash: SHA1
>>>> Hello devs,
>>>> I have submitted my proposal for GSoC 2010 project - RESTful API
>>>> for Mapbender at http://socghop.appspot.com under the Organization
>>>> OSGeo.
>>>> Please  go through the proposal and suggest me changes. I still have
>>> time
>>>> till 9th April 2010 to edit the proposal. I will be really grateful
>>>> to
>>> you
>>>> people for reviewing the application.
>>>> Anticipating response,
>>>> Regards
>>>> Vikash
>>> Vikash,
>>> thank you for submitting the proposal. Before submitting my comments
>>> to the GSoC site please consider the following details:
>>> I have a question and suggestion wrt the work plan. Why do you want
>>> to first implement the client side request of the API and then the
>>> server side?
>>> I was wrong when I said that client side should be designed first.
>>> Logical
>> thing will be to design the server side processing.
>> Regards
>> Vikash
>>> We should also clean out terminology, what is the client side and
>>> what is the server side, what is the back end. We could add this as a
>>> work package to the first three week design period.
>>> After GSoC starts - First three weeks -
>>> Add:
>>> ... "Update the Glossary of the project to describe the use of the
>>> terms "client", "server", "back end", "application", etc. in the
>>> context of the project"
>>> After first three weeks to Mid-term -
>>> Add:
>>> ... "We will use a test driven development method and follow the Scrum
>>>  process with daily scrums (as the availability of mentor and student
>>>  will allow).
>>> Please consider answering for this question:
>>> "How does your SoC task benefit the OSGeo member project, and more
>>> generally the OSGeo Foundation as a whole?"
>>> Suggestion:
>>> "The REST-API project will make it easier to integrate Mapbender with
>>> other projects. It will also allow machine access to the management
>>> back end data and improve the use of the project as centralized
>>> management back end for spatial data infrastructures. This will
>>> further improve the USP of the project."
>>> "Please provide details of previous GIS experience"
>>> I suggest you say: "None". This will not be a problem for us (as you
>>> already say further down). The project and tasks involved do not
>>> require you to have up front knowledge of GIS.
>>> I will talk over the proposal with Christoph but as far as I am
>>> concerned this is already a good proposal. I am happy with it.
>>> Best regards,
>>> Arnulf.
>>> Arnulf Christl
>>> Exploring Space, Time and Mind
>>> http://arnulf.us
>>> -----BEGIN PGP SIGNATURE-----
>>> Version: GnuPG v1.4.9 (GNU/Linux)
>>> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
>>> iEYEARECAAYFAku7EIUACgkQXmFKW+BJ1b0nNACfTBiLwnHBQ+ATT0gEhJ1oTha4
>>> SOkAn0nmFrIVS4OUXJ9ign+rV1oi58VC
>>> =SZ5N
>>> -----END PGP SIGNATURE-----
>>> Mapbender_dev mailing list
>>> Mapbender_dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Mit freundlichen Grüßen
Astrid Emde
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
 Astrid Emde
 WhereGroup GmbH & Co.KG
 Siemensstraße 8
 53121 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 19
 Fax: +49(0)228 90 90 38 - 11
 www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
