[Mapbender_dev] Fwd: [OSGeo-Discuss] Automatic-Metadata Catalogueing
Seven (aka Arnulf) seven at arnulf.us
Mon Aug 23 12:54:46 EDT 2010
This sounds like an interesting topic to learn from. I suggest that we
follow up and maybe provide a demo to let him use for testing?
Regards,
A
-------- Original Message --------
Subject: [OSGeo-Discuss] Automatic-Metadata Catalogueing
Date: Mon, 23 Aug 2010 16:40:44 +0000 (UTC)
Reply-To: OSGeo Discussions <discuss at lists.osgeo.org>
To: discuss at mail.osgeo.org
Hello,
I have piled up quite some data for a current project.
In order to keep track of the data I would like to use some automatic
indexing
to create a data catalog.
The idea is to cycle through all folders and sub-folders and create a
catalogue
which shows:
* basic data (projection, extend)
* attribute table columns
* data preview
I found two solutions:
* SpatialDataCataloguingScript at
http://code.google.com/p/spatialguru/wiki/SpatialDataCataloguingScript
=> this works well after some fixing.
But how do I best use the generated XML file?
Apparently, gvSIG has some tool as well:
Semi-automatic Metadata Extraction from Imagery and Cartographic data
http://www.geoinfo.uji.es/pubs/igarss07-metadata-cameraready.pdf
What can you recommend?
Thanks in advance,
Timmie
Discuss mailing list
Discuss at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/discuss
More information about the Mapbender_dev mailing list
