[Mapbender_dev] Mapbender , mapserver and WMS service getreatureinfo problem!!
Michael Schulz mschulz at webgis.de
Wed Aug 25 11:34:33 EDT 2010
yes, unfortunately that it the case. MapServer can not (at the moment)
cascade getfeatureinfo requests. Because of that the corresponding
layer has set queryable to 0/false and is thus not configurable as a
query layer in Mapbender's GUI-WMS settings.
I haven't tested this, but you might want to have a look at mapproxy,
it seems capable of doing cascaded WMS-getfeatureinfo requests.
Cheers, Michael
2010/8/25 necipakca <necipakca84 at hotmail.com>:
> Hi everyone ,
> First of all,I am a new user of mapbender and I have started a project with
> that i choosen mapbender.
> my problem is,
> i want to use getfeatureinfo property,but I am using WMS service in my
> project and I integrated its with mapserver.when i was load mapserver URL,I
> couldn't use getfeatureinfo.
> can i use getfeatureinfo with that mapserver and  "CONNECTIONTYPE  WMS"?
> my map file is that;
> MAP
> NAME  BuskiUser
> STATUS ON
> SIZE 400 400
> EXTENT 25.4821561784467 39.933353207504 26.6589862096445 40.5283797154684
> IMAGETYPE    png
> WEB
> IMAGEPATH    "C:\ms4w\tmp"
>    METADATA
>      "WMS_SRS"   "epsg:4326"
>      "WMS_FEATURE_INFO_MIME_TYPE"    "text/html"
>    END
> END
> PROJECTION
> "init=epsg:4326"
> END
>   LAYER
>      NAME    "sinir_ilce"
>      DATA "sinir_ilce"
>      TYPE POLYGON
>      DEBUG 1
>      DUMP TRUE
>      CONNECTION      "http://192.168.1.45:5656/denemewms/Request.aspx?"
>      CONNECTIONTYPE  WMS
>      METADATA
>        "wms_crs"             "epsg:4326"
>        "wms_name"            "SINIR_ILCE_SNR"
>        "WMS_TITLE"    "sinir_ilce"
>        "wms_server_version"    "1.1.1"
>        "wms_format"           "image/png"
>         "wms_request_method" "POST"
>      END
>      TEMPLATE "info.html"
>      PROJECTION
>         "init=epsg:4326"
>      END
>   END
> END  # of map file
> Is there anyone to help me to get rid of this situation.?
> Thanks,,
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Mapbender-mapserver-and-WMS-service-getreatureinfo-problem-tp5461648p5461648.html
> Sent from the mapbender-dev mailing list archive at Nabble.com.
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Aufwind durch Wissen!
Qualifizierte Open Source Schulungen bei der
http://www.foss-academy.eu/
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
Schwimmbadstraße 2
D-79100  Freiburg i. Br.
Tel:  +49 (0)761 705798-102
Tel:  +49 (0)761 705798-0
Fax: +49 (0)761 705798-09
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_dev mailing list
