[Mapbender_dev] Re: [Mapbender] #731: Gazetter fails to load WFS config
Mapbender mapbender_dev at lists.osgeo.org
Tue Dec 7 05:30:03 EST 2010
  Reporter:  christoph  |       Owner:  dev
      Type:  defect     |      Status:  closed
  Priority:  major      |   Milestone:  2.7 release
 Component:  wfs        |     Version:  2.6.2
Resolution:  fixed      |    Keywords:
Changes (by christoph):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 The WFS config IDs were added in wfsConfIdString "8,17". The problem was
 that config "8" was not loaded into the application. The WFS Config class
 didn't succeed in loading the following configs ("17"). The solution was a
 foreach loop, instead of of a for loop.
 changeset:7192
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/731#comment:1>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
