[Mapbender-dev] Re: [Mapbender] #595: BBOXes for all SRS in WMS-Capabilities
Mapbender mapbender_dev at lists.osgeo.org
Thu Feb 18 03:29:45 EST 2010
  Reporter:  frankjaeger     |       Owner:  dev
      Type:  enhancement     |      Status:  new
  Priority:  major           |   Milestone:  2.7 release
 Component:  administration  |     Version:  2.6
Resolution:                  |    Keywords:  SRS, BoundingBox
Comment (by armin11):
 hello frank,
 we made a solution which generates the bbox for a list srs which is
 defined in the mapbender.conf. the results are stored in the layer_epsg
 table. this can be seen as an extension to the information in the
 capabilities documents and allows the mapbender client to start withg
 other extents. qwe use this to have a faster access to the bbox of the
 layer and to zoom to layer positions. i think we can merge this function
 and adopt it to work although on update of wms.
 greetings armin
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/595#comment:1>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
