[Mapbender_dev] Admins: [Fwd: Re: [SAC] Projects VM and WebExtra migration]
Michael Schulz mschulz at webgis.de
Thu Jul 1 03:47:24 EDT 2010
in the osgeo trac, I assume?
BTW, I get the same error as Christoph when ssh'ing mapbender.telascience.org
Michael
2010/7/1 Seven (aka Arnulf) <seven at arnulf.us>:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Michael Schulz wrote:
>> Hi Arnulf,
>> no luck, just tried again, same problem. Permission denied ...
>> Cheers, Michael
> Can you please file a ticket?
> Christoph,
> I just closed your ticket with a "worksforme". Can you please also retry
> and reopen if it still gives you the error?
> http://trac.osgeo.org/osgeo/ticket/595
> Thanks, Arnulf
>> Michael,
>> can you please retry using this server:
>> ssh [yourname]@projects.osgeo.osuosl.org
>> It works for me and Uli and a few others, so there should be no
>> difference to your account.
>> We do not have sudo powers. I will write an email to SAC explaining what
>> we need and then see how they plan to get this organized.
>> Best regards,
>> Arnulf.
>>>>> Hi,
>>>>> nope, can't login in with my osgeo account (that works with osgeo svn
>>>>> and osgeo site).
>>>>> Cheers, Michael
>>>>> 2010/6/21 Uli Rothstein (WhereGroup) <uli.rothstein at wheregroup.com>:
>>>>>> Hey,
>>>>>> login is fine but the sudo is not working....
>>>>>> Uli
>>>>>> Christoph Baudson (Wheregroup) schrieb:
>>>>>>> Works for me...
>>>>>>> but is mapbender.telascience.org dead? See
>>>>>>> Confused,
>>>>>>> Christoph
>>>>>>> Astrid Emde wrote:
>>>>>>>> Hello admins,
>>>>>>>> I managed to login on the new VM with my OSGeo account.
>>>>>>>> Astrid
>>>>>>>> On Thu, June 17, 2010 6:01 pm, Seven (aka Arnulf) wrote:
>>>>>>> Admins,
>>>>>>> the Projects VM is now "almost" in place. Chris tries to do something to
>>>>>>> the sudoers file to make maintenance easier for project folks.
>>>>>>> Please try to log in with your OSGeo account for a start. It worked for
>>>>>>> me.
>>>>>>> I have no idea how that machine will survive the onslaught of 16 eager
>>>>>>> FOSS4G projects but we will see and learn... :-)
>>>>>>> Meanwhile we need to find out which folder to put in our eggs and hatch
>>>>>>> them.
>>>>>>> Best regards,
>>>>>>> Arnulf
>>>>>>> -------- Original Message --------
>>>>>>> Subject: Re: [SAC] Projects VM and WebExtra migration
>>>>>>> Date: Wed, 16 Jun 2010 17:49:26 +0200
>>>>>>> From: <christopher.schmidt at nokia.com>
>>>>>>> Reply-To: System Administration Committee Discussion/OSGeo
>>>>>>> <sac at lists.osgeo.org>
>>>>>>> To: <sac at lists.osgeo.org>
>>>>>>> References:
>>>>>>> <AANLkTin-3WlFS7-KZO9xLZ06vKhd-h-DBTZwx7OewaO9 at mail.gmail.com>
>>>>>>> On Jun 16, 2010, at 11:37 AM, ext Frank Warmerdam wrote:
>>>>>>>>>>> Folks,
>>>>>>>>>>> As discussed at our meeting, the WebExtra VM has
>>>>>>>>>>> been moved from osgeo4 to osgeo3 by Lance at OSU OSL. He mentions that
>>>>>>>>>>> the system usage looks like this:
>>>>>>>>>>> Node              DTotal  DFree MTotal MNode MFree Pinst Sinst
>>>>>>>>>>> osgeo3.osuosl.bak 671.0G 468.7G  47.3G 30.3G 31.0G     6     0
>>>>>>>>>>> osgeo4.osuosl.bak   1.1T 283.6G  47.3G 26.2G 34.3G     3     2
>>>>>>>>>>> Lance has also created the projects VM as discussed, and
>>>>>>>>>>> I have configured it to use the telascience shell authentication
>>>>>>>>>>> group.  So anyone with login access on the telascience xblades will
>>>>>>>>>>> also
>>>>>>>>>>> now have access on the projects VM. But currently the sudoer's list is
>>>>>>>>>>> still the standard set of SAC VMs.  As needed folks will need to ask an
>>>>>>>>>>> existing sudoer to add them to the sudoers list on the VM.
>>>>>>> I would like to try to make it so that people don't need to be
>>>>>>> sudoers for most everyday tasks. I am currently working on setting up
>>>>>>> the
>>>>>>> VM for projects to migrate to in a sane way without needing
>>>>>>> to have sudo access for every task. As a result, I'd like for
>>>>>>> projects to
>>>>>>> hold off on migrating to the projects VM until after this weekend, if
>>>>>>> possible; if I don't get stuff done, we can go ahead and work without
>>>>>>> this, but I'd like to take a crack at this first.
>>>>>>> -- Chris
>>>>>>>>>>> The VM can be reached as:
>>>>>>>>>>> I shall endevour to write up some information in the wiki
>>>>>>>>>>> about the VM, and perhaps establishing some advice about "good
>>>>>>>>>>> behavior"
>>>>>>>>>>> on the VM since many projects will be cohabitating there.
>>>>>>>>>>> Best regards,
>>>>>>>>>>> I set the clouds in motion - turn up   | Frank Warmerdam,
>>>>>>>>>>> warmerdam at pobox.com light and sound - activate the windows |
>>>>>>>>>>> http://pobox.com/~warmerdam
>>>>>>>>>>> and watch the world go round - Rush    | Geospatial Programmer for Rent
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> Sac mailing list
>>>>>>>>>>> Sac at lists.osgeo.org
>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/sac
>>>>>>> Regards,
>>>>>> Mapbender_dev mailing list
>>>>>> Mapbender_dev at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
>>>>>> Ulrich Rothstein
>>>>>> WhereGroup GmbH & Co. KG
>>>>>> Siemensstraße 8
>>>>>> 53121 Bonn
>>>>>> Germany
>>>>>> Fon: +49 (0)228 / 90 90 38 - 17
>>>>>> Fax: +49 (0)228 / 90 90 38 - 11
>>>>>> mailto:uli.rothstein at wheregroup.com
>>>>>> www.wheregroup.com
>>>>>> Amtsgericht Bonn, HRA 6788
>>>>>> Komplementärin:
>>>>>> WhereGroup Verwaltungs GmbH
>>>>>> vertreten durch:
>>>>>> Olaf Knopp, Peter Stamm
> Arnulf Christl
> Exploring Space, Time and Mind
> http://arnulf.us
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.9 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iEYEARECAAYFAkwsRxwACgkQXmFKW+BJ1b2QrgCfdcFAA1NyQn4R/wyOdPIirIY0
> mUUAnRw0HCsaz7rA39PdxMf4gM8qZ/Y3
> =KSt9
> -----END PGP SIGNATURE-----
Aufwind durch Wissen!
Qualifizierte Open Source Schulungen bei der
http://www.foss-academy.eu/
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
Schwimmbadstraße 2
D-79100  Freiburg i. Br.
Tel:  +49 (0)761 705798-102
Tel:  +49 (0)761 705798-0
Fax: +49 (0)761 705798-09
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_dev mailing list
