[Mapbender_dev] Handling REST API requests.
Armin Retterath armin.retterath at lvermgeo.rlp.de
Mon Jul 12 03:00:55 EDT 2010
ok - if index.php/user/25 will do the job without any further rewriting
i don't know this behavior til now.
regards from koblenz
armin
Am Montag 12 Juli 2010, um 08:46:58 schrieb Karim Malhas:
> On Mon, Jul 12, 2010 at 07:33:38AM +0200, Armin Retterath
> <armin.retterath at lvermgeo.rlp.de> wrote
> > hello together,
> > i would prefer 1)
> > cause i think that nice urls are the key for our problems.
> What an URL looks like doesn't matter at all for a computer, and
> shouldn't for a human - they should be hidden behind the text of a
link.
> I find clean, nice URLs useful when looking at the locationbar to find
> out where I am, or when sharing an URL to serve as a clue as to what
> can be expected at that address.
> So while I think nice URLs are good, I don't consider them a
neccessity.
> That said: I read what I wrote again, and I think I wasn't clear
enough.
> Option 2) uses URLs like "/index.php/user/25" and also easily allows
for a
> rewrite configuration that can look something like "/user/25"
> > regards,
> > armin
> > Am Sonntag 11 Juli 2010, um 16:32:04 schrieb Karim Malhas:
> > > > > You can have a single script for each resource type in the
> > approach I
> > > > > mentioned. Think of it like this
> > > > > api/users.php/json
> > > > > api/user.php/<id>/json
> > > > > api/wms.php/<id>/json>
> > > > > etc.
> > > > Even if it is api/users.php/json
> > > > when the client will send a request GET api/users/json , the
server
> > will
> > > > look for api/users/json/index.php or api/users/json/index.html
> > > I don't understand the "GET api/users/json" request, what is that
> > > supposed to get?
> > > Let me try to give a summary of the discussion so far :
> > > 1) Map all paths to /index.php and do all the path-parsing there
> > >   example: "/user/25" is rewritten to /index.php which can then
> > >   parse "/user/25"
> > >   advantage: nice URLs
> > >   disadvantage: additional configuration in the webserver needed
> > > 2)
> > >   Give the path as an argument to index.php
> > >   example: "/index.php/user/25" will call /index.php which can
then
> > >   parse "/user/25"
> > >   advantage:  simple, can be used together with a rewrite
> > > 3)
> > >   like 2), but for each Resource
> > >   there's a ".php"  in each url, which could be gotten rid of
> > >   with URL rewiriting but it's more work than in 2)
> > > Me my personal preference would be 2)
> > > I would also prefer specify Content-Type as ".json" not "/json", so
you
> > > don't have to treat it as a special case in path parsing
> > > Regards,
> > > Karim
> > > _______________________________________________
> > > Mapbender_dev mailing list
> > > Mapbender_dev at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Im Auftrag
Armin Retterath
Kompetenz- und Geschäftsstelle Geodateninfrastruktur Rheinland-Pfalz
beim
Landesamt für Vermessung und Geobasisinformation Rheinland-Pfalz
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
Telefon 0261/492-466
Telefax 0261/492-492
http://www.geoportal.rlp.de
More information about the Mapbender_dev mailing list
