[Mapbender_dev] mental notes on installation shell script
Thomas Baschetti
info at thomas-baschetti.de
Wed Jul 21 13:24:46 EDT 2010
On 21.07.2010 18:10, Astrid Emde wrote:
> Hello Christoph,
> your suggestions sound good.
> On Wed, July 21, 2010 3:04 pm, Christoph Baudson (Wheregroup) wrote:
>> Hello developers,
>> here are some mental notes on the installation script
>> (resources/db/install.sh). we could
>> - copy mapbender.conf-dist to mapbender.conf
> good idea
> although we should ask the user, whether to create the file, as sometimes
> I just want to create a new database and already have a mapbender.conf
> file.
we already do this:
# creating mapbender.conf
if [ -f ../../conf/mapbender.conf ]
then
echo "mapbender.conf already exists, not changed"
else
cp ../../conf/mapbender.conf-dist ../../conf/mapbender.conf
fi
echo ""
echo "please check and edit the entries in your mapbender.conf
manually!"
>> - add database information to mapbender.conf (via sed). The values are
>> already being read from command line - concatenate all relevant SQLs into
>> one temporary file via cat (the password is only requested once if a
>> single file is executed, and not n times)
> good idea
but...
>> I'm not sure how this would work under Windows.
> should work with windows aswell.
...sorry, no sed with windows.
>> These additions might seem trivial, but would make an installation even
>> less work.
> yes, yes.
> Does someone volunteers to integrate the enhancements?
/me is ducking and hiding, no space left on device this week...
(and i owe you a webinstaller anyway so i keep calm ond hope nobody notices)
Ciao
Thomas
Thomas Baschetti - Systemanalyse Geographische Informationssysteme
Hakenstraße 8D
49074 Osnabrück
Tel: 0541 25 91 90 | mobil 01577 189 25 91
E-Mail: info at thomas-baschetti.de
www.thomas-baschetti.de
Ust-IdNr.: DE264355072
More information about the Mapbender_dev
