[Mapbender_dev] Admins: [Fwd: Re: [SAC] Projects VM and WebExtra migration]
Michael Schulz mschulz at webgis.de
Wed Jun 30 09:17:41 EDT 2010
nope, can't login in with my osgeo account (that works with osgeo svn
and osgeo site).
Cheers, Michael
2010/6/21 Uli Rothstein (WhereGroup) <uli.rothstein at wheregroup.com>:
> Hey,
> login is fine but the sudo is not working....
> Uli
> Christoph Baudson (Wheregroup) schrieb:
>> Works for me...
>> but is mapbender.telascience.org dead? See
>> http://trac.osgeo.org/osgeo/ticket/595
>> Confused,
>> Christoph
>> Astrid Emde wrote:
>>> Hello admins,
>>> I managed to login on the new VM with my OSGeo account.
>>> Astrid
>>> On Thu, June 17, 2010 6:01 pm, Seven (aka Arnulf) wrote:
>> Admins,
>> the Projects VM is now "almost" in place. Chris tries to do something to
>> the sudoers file to make maintenance easier for project folks.
>> Please try to log in with your OSGeo account for a start. It worked for
>> me.
>> I have no idea how that machine will survive the onslaught of 16 eager
>> FOSS4G projects but we will see and learn... :-)
>> Meanwhile we need to find out which folder to put in our eggs and hatch
>> them.
>> Best regards,
>> Arnulf
>> -------- Original Message --------
>> Subject: Re: [SAC] Projects VM and WebExtra migration
>> Date: Wed, 16 Jun 2010 17:49:26 +0200
>> From: <christopher.schmidt at nokia.com>
>> Reply-To: System Administration Committee Discussion/OSGeo
>> <sac at lists.osgeo.org>
>> To: <sac at lists.osgeo.org>
>> References:
>> <AANLkTin-3WlFS7-KZO9xLZ06vKhd-h-DBTZwx7OewaO9 at mail.gmail.com>
>> On Jun 16, 2010, at 11:37 AM, ext Frank Warmerdam wrote:
>>>>>> Folks,
>>>>>> As discussed at our meeting, the WebExtra VM has
>>>>>> been moved from osgeo4 to osgeo3 by Lance at OSU OSL. He mentions that
>>>>>> the system usage looks like this:
>>>>>> Node              DTotal  DFree MTotal MNode MFree Pinst Sinst
>>>>>> osgeo3.osuosl.bak 671.0G 468.7G  47.3G 30.3G 31.0G     6     0
>>>>>> osgeo4.osuosl.bak   1.1T 283.6G  47.3G 26.2G 34.3G     3     2
>>>>>> Lance has also created the projects VM as discussed, and
>>>>>> I have configured it to use the telascience shell authentication
>>>>>> group.  So anyone with login access on the telascience xblades will
>>>>>> also
>>>>>> now have access on the projects VM. But currently the sudoer's list is
>>>>>> still the standard set of SAC VMs.  As needed folks will need to ask an
>>>>>> existing sudoer to add them to the sudoers list on the VM.
>> I would like to try to make it so that people don't need to be
>> sudoers for most everyday tasks. I am currently working on setting up
>> the
>> VM for projects to migrate to in a sane way without needing
>> to have sudo access for every task. As a result, I'd like for
>> projects to
>> hold off on migrating to the projects VM until after this weekend, if
>> possible; if I don't get stuff done, we can go ahead and work without
>> this, but I'd like to take a crack at this first.
>> -- Chris
>>>>>> The VM can be reached as:
>>>>>> projects.osgeo.osuosl.org
>>>>>> I shall endevour to write up some information in the wiki
>>>>>> about the VM, and perhaps establishing some advice about "good
>>>>>> behavior"
>>>>>> on the VM since many projects will be cohabitating there.
>>>>>> Best regards,
>>>>>> I set the clouds in motion - turn up   | Frank Warmerdam,
>>>>>> warmerdam at pobox.com light and sound - activate the windows |
>>>>>> http://pobox.com/~warmerdam
>>>>>> and watch the world go round - Rush    | Geospatial Programmer for Rent
>>>>>> _______________________________________________
>>>>>> Sac mailing list
>>>>>> Sac at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/sac
>> Regards,
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
> Ulrich Rothstein
> WhereGroup GmbH & Co. KG
> Siemensstraße 8
> 53121 Bonn
> Germany
> Fon: +49 (0)228 / 90 90 38 - 17
> Fax: +49 (0)228 / 90 90 38 - 11
> mailto:uli.rothstein at wheregroup.com
> www.wheregroup.com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
Aufwind durch Wissen!
Qualifizierte Open Source Schulungen bei der
http://www.foss-academy.eu/
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
Schwimmbadstraße 2
D-79100  Freiburg i. Br.
Tel:  +49 (0)761 705798-102
Tel:  +49 (0)761 705798-0
Fax: +49 (0)761 705798-09
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_dev mailing list
