[Mapbender-dev] Datamodel designer for PG
Michael Schulz mschulz at webgis.de
Sat Mar 13 14:16:43 EST 2010
yeah, the reporting tools look promising and it has a pretty broad
feature spectrum.
We're using for some time this data modelling tool:
http://www.sqlpower.ca/page/architect,
It's to some extent DB-independant. You can create a modell and
generate the code for different db systems.
One drawback is that geometry columns are not supported. One thing
I've just read is that it can compare db models... sounds interesting
wrt. updating.
Cheers, Michael
2010/3/13 Arnulf Christl (aka Seven) <seven at arnulf.us>:
> Hi,
> just found this http://sourceforge.net/projects/pgdesigner/ on the
> Spanish OSGeo-list. Looks like it might be handy for visual
> documentations.
> Regards,
> Arnulf.
> http://arnulf.us
> Exploring Space, Time and Mind
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Aufwind durch Wissen!
Qualifizierte Open Source Schulungen bei der
http://www.foss-akademie.de/
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
+++ Bitte beachten Sie unsere neue Adresse und Durchwahl +++
Schwimmbadstraße 2
D-79100  Freiburg i. Br.
Tel:  +49 (0)761 705798-102
Tel:  +49 (0)761 705798-0
Fax: +49 (0)761 705798-09
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_dev mailing list
