[Mapbender_dev] PDO
Astrid Emde astrid.emde at wheregroup.com
Fri Oct 1 01:20:45 EDT 2010
Hello Christoph,
good idea to use PDO for database access.
I only have some questions.
Are the spatial queries (area, transform, length ...) still running with
the PDO solution?
Does the PDO usage has any negative impact? Or only positive ones?
Whch are the rare functions?
Astrid
On Wed, September 29, 2010 6:54 pm, Christoph Baudson wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi list,
> yesterday Karim taught me what he knew about database unit testing in PHP,
> where PDO [1] is apparently required. As database unit testing is quite
> essential in Mapbender, I experimented a little with PDO.
> I used database-pgsql.php [2] as a wrapper for PDO, and also created a
> singleton for the database handle [3].
> At the moment I have trunk running with PDO. An open problem are rarely
> used db functions which can't be mapped to PDO. I will have to address
> these later on, but this should not take long.
> When this is done I can merge my changes back to trunk and we can start
> building database unit tests.
> Christoph
> [1] http://php.net/manual/de/book.pdo.php
> [2]
> http://trac.osgeo.org/mapbender/browser/branches/mapbender/lib/database-pg
> sql.php [3]
> http://trac.osgeo.org/mapbender/browser/branches/mapbender/lib/class_Mapbe
> nder_database.php -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.9 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iEYEARECAAYFAkyji2YACgkQGtMIfbycMX6WYQCgmEfPPmddskXZaaE2nkgLCaDo
> iLcAn2mhzFLKR6lMlnuu7LF30JTwvu56 =3wVJ
> -----END PGP SIGNATURE-----
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Mit freundlichen Grüßen
Astrid Emde
INTERGEO 2010
05.-07. Oktober 2010 in Köln
Halle 11.2, Stand 2C.121
www.intergeo.de
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
 Astrid Emde
 WhereGroup GmbH & Co.KG
 Siemensstraße 8
 53121 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 19
 Fax: +49(0)228 90 90 38 - 11
 www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
