[Mapbender_dev] Writing tests for GeoJSON to GML converter
Christoph Baudson christoph.baudson at wheregroup.com
Tue Oct 5 10:59:42 EDT 2010
Christoph Baudson wrote:
> Hello list,
> is there anyone willing to write unit tests for the GeoJSON to GML
> converter?
> Due to a problem in trunk, I added a test case for donut polygons and
> GML2, see [1]. We could easily extend the coverage to all geometry
> types (points, multipoints, lines, multilines, polygons, donut
> polygons (done), multipolygons, donut multipolygons) in both GML2 and
> GML3, we just need data. You could use the standard gui_digitize for
> GML2.
> The process is simple: First, add a new test case for each geometry
> type. Then digitize each geometry, and save it to the default
> featuretype (edit_polygons, edit_lines, edit_points). You can get the
> GeoJSON from Firebug. If saving succeeds, get the GML from the logs,
> and validate against it.
> If you have any questions, please let me know. It's a fairly easy task
> and you can learn about PHPUnit this way.
Jonas (intern at WhereGroup) has successfully added these tests to SVN.
I will have to do a code review later on, but the tests are more or less
complete.
Thanks to Jonas for his work :-)
Christoph
> Christoph
> [1]
> http://trac.osgeo.org/mapbender/browser/trunk/mapbender/test/http/classes/Gml2FactoryTest.php
INTERGEO 2010
05.-07. Oktober 2010 in Köln
Halle 11.2, Stand 2C.121
www.intergeo.de
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
