[Mapbender_dev] hi evreybody, i think there is a problem abouth WFS search via GeoServer WFS Service !
Verena Diewald verena.diewald at wheregroup.com
Fri Oct 8 08:43:59 EDT 2010
Am 08.10.2010 13:49, schrieb necipakca:
> hi,
> The sound is great!!
> but, i think there is a problem,too:(. it relate abouth again with WFS. i am
> creating new a Wfs conf. on my wfs service.after,i am add my gui from 'asign
> WFS conf to gui'. problem is that wfsConfStringId which is in
> gui_elements_vars does not update.so i don't see it in my gui. if i add
> wfs_conf_id to wfsConfStringId which is own my gui,Every thing is ok.it
> works very well.
You always have to edit the element var wfsConfIdString on your own if
you want to use a new WFS conf for that. That is the normal behaviour of
Mapbender.
> i have examined to code,but i did not find that which is update
> wfsConfStringId.my php knowledge is not fine maybe so...:)
> by the way i receive like this error when adding conf. in my gui,
> Notice: administration->getGuisByPermission is deprecated, use
> user->getApplicationsByPermission instead!
> ERROR:
> a:17:{i:0;s:22:"deneme";i:1;s:9:"admin2_de";i:2;s:9:"admin2_en";i:3;s:17:"admin_de_services";i:4;s:17:"admin_en_services";i:5;s:3:"gui";i:6;s:4:"gui1";i:7;s:4:"gui2";i:8;s:12:"gui_digitize";i:9;s:10:"wms_africa";i:10;s:13:"wms_australia";i:11;s:10:"wms_europe";i:12;s:11:"wms_germany";i:13;s:17:"wms_north_america";i:14;s:13:"wms_worldwide";i:15;s:10:"wms_gdi_de";i:16;s:6:"admin1";}
This "ERROR" is only a log message in one of the classes scripts which
probably someone forgot to remove after testing. I removed it from the
code now.
Best regards,
Verena
> Regards,
> Necip AKCA
More information about the Mapbender_dev mailing list
