[Mapbender_dev] [Mapbender] #713: GUI Layer styles not set correctly
Mapbender mapbender_dev at lists.osgeo.org
Mon Oct 18 11:16:11 EDT 2010
 Reporter:  mschulz  |       Owner:  dev
     Type:  defect   |      Status:  new
 Priority:  major    |   Milestone:  2.7 release
Component:  wms      |     Version:  2.7 rc1
 Keywords:           |
 GUI Layer styles with a style name other than "default" are not correctly
 loaded on an applications startup. E.g. Geoserver layer often have special
 style names. In the startup of a gui, the wms array is created from
 class_wms, transferred into a wmc-object/xml and assigned then to the map.
 In this procedure the named styles information is lost.
 I'll add more information to his bug, when I've digged further. So far I
 could observe this behaviour by examining class_wmc setLayerData method,
 when it adds a layer to currentWMS (line 1666).
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/713>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
