[Mapbender_dev] Re: [Mapbender] #772: Login count does not count on false
Mapbender mapbender_dev at lists.osgeo.org
Fri Feb 11 10:58:40 EST 2011
  Reporter:  astrid_emde     |       Owner:  dev
      Type:  defect          |      Status:  closed
  Priority:  major           |   Milestone:  2.7 release
 Component:  administration  |     Version:  2.7 rc1
Resolution:  fixed           |    Keywords:
Changes (by astrid_emde):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 notice in mapbender.conf-dist, that this parameter is not in use anymore
 A different solution should be worked out
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/772#comment:1>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
