[Mapbender_dev] Still a little bug in french translation
Astrid Emde astrid.emde at wheregroup.com
Mon Jun 6 05:43:22 EDT 2011
On Fri, June 3, 2011 2:35 pm, zorg wrote:
> HI
> Here is a little bug in the french translation
> In the table translation
> the line with trs_id
> "trs_id"
> "360"
> "379"
> "383"
> "384"
> "386"
> got translation text with single quote in it (')
> so it screw up all the map using this button
> Is it possible to modify it or double quote the alt attributen
> hope i'm clear
Salut zorg,
we do not have so many french Mapbender installations and did not realize
the error yet.
I wrote an update SQL to replace the '. Would this be ok? Could you please
try the applications? It works for me. I would fix it in the Mapbender svn
afterwards.
-- 360
UPDATE translations set msgstr = 'Sauvegarder la vue/l`espace de travail
en tant que Web Map Context'
where locale = 'fr' and msgid = 'Save workspace as web map context document';
--379
UPDATE translations set msgstr = 'Carte d`aperçu'
where locale = 'fr' and msgid = 'Overview';
-- 383
UPDATE translations set msgstr = 'Sélection de l`échelle'
where locale = 'fr' and msgid = 'Scale Select';
-- 384
UPDATE translations set msgstr = 'Texte de l`échelle'
where locale = 'fr' and msgid = 'Scale Text';
--386
UPDATE translations set msgstr = 'Sélectionner la carte d`arrière-plan'
where locale = 'fr' and msgid = 'Set Background';
Mit freundlichen Grüßen
Astrid Emde
AGIT 2011
6.-8. Juli 2011 in Salzburg
Treffen Sie die WhereGroup an Stand Nr. 30
http://www.agit.at
 Astrid Emde
 WhereGroup GmbH & Co.KG
 Eifelstraße 7
 53119 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 19
 Fax: +49(0)228 90 90 38 - 11
 www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
