[Mapbender_dev] [Mapbender] #839: login.php application overview - change switch on mouseover to click
Mapbender mapbender_dev at lists.osgeo.org
Tue Jun 21 02:20:27 EDT 2011
 Reporter:  astrid_emde     |       Owner:  dev
     Type:  defect          |      Status:  new
 Priority:  major           |   Milestone:  2.7.2 release
Component:  user interface  |     Version:  2.7.1
 Keywords:                  |
 * it makes sense to change the tab switch on click instead of mouseover.
 (Problem with mouseover: When you have many categories you get more then
 one row of tabs it is not so easy to get to the applications of a tab in
 the first row)
 This is the suggestion of the change in the code:
  * event: 'click'
 $(document).ready(function () {
         $(function() {
                 $("#guiListTabs").tabs({
                         event: 'click'
 false; });
 Opinions?
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/839>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
