Fwd: Re: Fwd: Re: [Mapbender_dev] Printing High Quality 288dpi Blank PDF
Armin Retterath armin.retterath at lvermgeo.rlp.de
Tue Jun 28 00:57:29 EDT 2011
hello dave,
you have to do some further investigations i think. please first send me the
version number of your mapbender installation. you should make some debug
output at the right line of your class_connector.php to see which wms getmap
url was requested. now i think there will be no error thrown by mapbenders
print script.
i think it may have something to do with the mapserver. which version of
mapserver do you use? as i know there have been some errors with maxsize in
v5.6. do you have defined different scalehints for the single layers?
regards
armin
Am Montag 27 Juni 2011, 16:57:15 schrieb daveyclark:
> Armin
> Many Thanks for your responses.
> I have made your suggested changes by reverting my previous changes in the
> class_connector.php and also changed my MAXSIZE to 5000.
> I am getting something now, but not much. I am now getting my boundary
> layer, but nothing else. All I am getting is a black line on the white
> page, i.e. my boundary, but not ontop of a map like its ment to be, map is
> just not showing.
> Could it be where my MAXSIZE is defined in the wms.map? It is currently
> right at the top, the next line after MAP.
> If it is that, where would be best to put this? Or does it need to be
> defined in each layer? If it's not that, then not sure what is wrong now.
> Regards
> Dave
> http://osgeo-org.1803224.n2.nabble.com/Fwd-Re-Fwd-Re-Mapbender-dev-Printin
> g-High-Quality-288dpi-Blank-PDF-tp6520557p6520775.html Sent from the
> mapbender-dev mailing list archive at Nabble.com.
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Im Auftrag
Armin Retterath
Zentrale Stelle Geodateninfrastruktur
LVermGeo RP
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
Telefon 0261/492-466
Telefax 0261/492-492
http://www.geoportal.rlp.de
More information about the Mapbender_dev mailing list
