Fwd: Re: Fwd: Re: [Mapbender_dev] Printing High Quality 288dpi Blank PDF
Armin Retterath armin.retterath at lvermgeo.rlp.de
Tue Jun 28 04:39:56 EDT 2011
hi dave,
in
http://trac.osgeo.org/mapbender/browser/branches/2.7/http/classes/class_connector.php#L81
you should see the mb_notice. alter this to mb_exception - the url will be
written to mapbenders error log as you ve seen it before.
copy the urls to your browser and check the returning picture.
please send a copy of the url to this mailing list.
your mapfile don't seem to be a valid mapfile to serve ows. please have a look
at:
http://mapserver.org/ogc/index.html#ogc
e.g.:
MINBOXSIZE 10
MAXBOXSIZE 150
SCALEBAR
QUERYMAP
REFERENCE
are no wms specific params and may have problems when mapserver serves images
over wms. (comment out the maxscaledenom/minscaledenom for testing)
please first make a simple wms mapfile for your background layers. check if
printing make problems. mapbender doesn't support all mapserver parameters,
cause it is mainly a client for ows.
regards
armin
Am Dienstag 28 Juni 2011, 10:02:39 schrieb daveyclark:
> Hi Armin
> My versions of software are listed below:
> PostgreSQL 8.4/pg Admin III/ PostGIS 1.5
> Appache Web Server 2.2.15
> Mapbender 2.7
> MapServer 5.6.5 CGI and MapScript (CSharp, Java, PHP, Python)
> PHP 5.3.2
> I have also pasted my wms.map file below to see if you think there are any
> problems in there.
> Many Thanks
> Dave
> *wms.map*
> # The annotated map file (sort of)
> # Created by Pericles S. Nacionales for the MapServer tutorial
> # 20050408
> # MapServer map file uses the pound sign (#) to denote the start of a line
> # comment--each line that needs to be commented has to be prepended with a
> # Map files begin with MAP keyword to signify the start of the map object.
> # Well, the entire map file is THE map object.  Enclosed between MAP and
> END # at the very bottom of this map file, are keyword/value pairs and
> other # objects.
> MAP
>   *MAXSIZE 5000*
>   CONFIG "PROJ_LIB" "p:/ms4w/proj/nad/"
>   IMAGETYPE      png24
> EXTENT 334160 728620 348810 736430
> #EXTENT 330000 725000 360000 740000
>   SIZE           900 640
>   SHAPEPATH      "../data"
>   SYMBOLSET      "../symbols/symbols35.sym"
>   FONTSET        "../fonts/fonts.list"
>   TEMPLATEPATTERN 'test4*'
>   PROJECTION
>     "init=epsg:27700"
>   END # This is the ending of the output projection
> #  TEMPLATEPATTERN 'test2_page*'
> # The web object is defined at the level below the map object.  All
> # web-related parameters (I interchange "parameters" and "keyword/value
> # pairs" quite frequently, sorry about that) are defined in this object.
>   WEB
> #    HEADER    '../templates/wms_header.html'
> #    FOOTER    '../templates/wms_footer.html'
> HEADER    '../templates/header.html'
> FOOTER    '../templates/footer.html'
>     TEMPLATE  'p:/ms4w/apps/tutorial/htdocs/wms_template.html'
>     IMAGEPATH 'p:/ms4w/tmp/ms_tmp/'
>     IMAGEURL  '/ms_tmp/'
>     METADATA
>       "wms_title"   "MY WMS Server"
>        "wms_onlineresource"
> "http://myserver/cgi-bin/mapserv.exe?MAP=p:/ms4w/apps/tutorial/htdocs/wms.m
> ap" #     "wms_onlineresource" "http://myserver/cgi-bin/mapserv.exe?"
>       "wms_srs"   "EPSG:27700"
>       "wms_server_version" "1.1.1"
>       "wms_feature_info_mime_type" "text/html"
>       "wms_abstract"      "This server was setup by me and is powered by
> MapServer. "
>     END
>   END # Every object in MapServer must have an END.;)
> #  PROJECTION
> #    "init=epsg:27700"
> #  END # This is the ending of the output projection
>   # Start of legend
>   LEGEND
>     KEYSIZE 12 12
>     LABEL
>       TYPE BITMAP
>       SIZE MEDIUM
>       COLOR 0 0 89
>     END
>     STATUS ON
>   END
>   # The reference object is used to define a reference map for your mapping
>   # application.  This typically involves defining a small image that
> covers # the entire area of the map and defining a box that represents the
> current
>   # view on in relation to the entire area.
>   REFERENCE
>     IMAGE '../images/ugl_ref1.png' # The reference image
>     SIZE 155 105 # The size of the reference image in pixels
> ##    EXTENT 201621.496941 -294488.285333 1425518.020722 498254.511514 #
> The extent of the reference image in map units
> #    EXTENT     330000.000000 720000.000000 340000.000000 730000.000000
> EXTENT 329999.683 725000.328 339999.672 740000.318
>     STATUS ON
>     MINBOXSIZE 10 # How small can the reference box be before it gets drawn
> as a point, in pixels
>     MAXBOXSIZE 150 # The maximum size of the reference box, in pixels
>     COLOR -1 -1 -1 # The reference box fill color, negative numbers mean
> transparent
>     OUTLINECOLOR 128 0 0 # The reference box outline color
>     MARKERSIZE 8 # The size of the point marker
>     MARKER 'star' # The marker symbol
>   END
>   # A scalebar object is defined one level below the map object.  This
> object
>   # controls how a scalebar is drawn by MapServer.  Scalebars can be
> embedded
>   # in the map itself or can be created as a separate image.  It has an
>   # associated MapServer CGI variable called "scalebar" (or [scalebar] when
>   # used in the HTML template).
> SCALEBAR
> INTERVALS 4
> UNITS meters
> STYLE 0
> STATUS off
>   LABEL
>     SIZE large
>     COLOR 0 0 0
>   END
> END
>   # A querymap object is used to highlight, or make prominent, the features
> on a
>   # map selected via a query or nquery request.   This means you can
> display # your query results and a map showing the features selected for
> the query.
>   QUERYMAP
>     SIZE 200 150
>     STATUS ON
>     STYLE HILITE  # SELECTED | NORMAL
>     COLOR 255 0 0
>   END
>   # Layer objects are defined beneath the map object.  You need at least
> one # layer defined in your map file before you can display a map...  You
> can # define as many layers as you'd like although a limit is typically
> hard-coded
>   # in map.h in the MapServer source.  The default limit is set at 100.
> You'd
>   # have to have a very specialized application to need more than 100
> layers in
>   # your application.
>   # Start of LAYER DEFINITIONS
>   LAYER
>     NAME tenk
>     PROJECTION
>       "init=epsg:27700"
>     END
>     TYPE RASTER
>     STATUS ON
>     TILEINDEX "p:\maps\10k\tay10.shp"
>     TILEITEM "Location"
>    MINSCALEDENOM 2000
>    MAXSCALEDENOM 10000
>     METADATA
> 	"wms_name"		"tenk"
> 	"wms_format"		"image/gif"
> 	"wfs_title"             "tenk" ##REQUIRED
> 	"wfs_srs"               "EPSG:27700" ## REQUIRED
> 	"gml_include_items"     "all" ## Optional (serves all attributes for
> layer) "gml_featureid"         "ID" ## REQUIRED
>     END
>     END
>   LAYER
>     NAME twentyfivek
>     PROJECTION
>       "init=epsg:27700"
>     END
>     TYPE RASTER
>     STATUS ON
>     TILEINDEX "p:\maps\25k\tay25.shp"
>     TILEITEM "Location"
>    MINSCALEDENOM 10000
>    MAXSCALEDENOM 25000
>     METADATA
> 	"wms_name"		"twentyfivek"
> 	"wfs_title"             "twentyfivek" ##REQUIRED
>     END
>     END
>   LAYER
>     NAME fiftyk
>     PROJECTION
>       "init=epsg:27700"
>     END
>     TYPE RASTER
>     STATUS ON
>     TILEINDEX "p:\maps\50k\tay50.shp"
>     TILEITEM "Location"
>    MINSCALEDENOM 25000
>    MAXSCALEDENOM 50000
>     METADATA
> 	"wms_name"		"fiftyk"
> 	"wfs_title"             "fiftyk" ##REQUIRED
>     END
>     END
>   LAYER
>     NAME twofiftyk
>     PROJECTION
>       "init=epsg:27700"
>     END
>     TYPE RASTER
>     STATUS ON
>     TILEINDEX "p:\maps\250k\tay250.shp"
>     TILEITEM "Location"
>    MINSCALEDENOM 50000
>    MAXSCALEDENOM 10000000
>     METADATA
> 	"wms_name"		"twofiftyk"
> 	"wfs_title"             "twofiftyk" ##REQUIRED
>     END
>     END
>   LAYER # DDArea polygon layer begins here
>     NAME         "topographicarea"
>     CONNECTIONTYPE postgis
>     CONNECTION "dbname=database user=admin password=password"
>     PROCESSING "CLOSE_CONNECTION=DEFER"
> #    DATA         "the_geom from ddarea USING UNIQUE gid USING SRID=27700"
>     DATA         "the_geom from topographicarea USING UNIQUE oid USING
> SRID=27700"
> #    MINSCALE     100000
>     STATUS       ON
>     TYPE         POLYGON
> #    MINSCALEDENOM 50000
>     MAXSCALEDENOM 2000
>   PROJECTION
>     "init=epsg:27700"
> HEADER    '../templates/ddarea_header.html'
> FOOTER    '../templates/ddarea_footer.html'
>     METADATA
> 	"wms_name"		"topographicarea"
> 	"wms_bgcolor"		"0xf0f0f0"
> 	"wfs_title"             "topographicarea" ##REQUIRED
>     END
>     # The class object is defined within the layer object.  You can define
> as
>     # many classes as you need (well, there are limits as with layers, but
> it's
>     # senseless to define more than ten on a "normal" layer.  There are
>     # situations, however, where you might have to do it.)
> #   CLASSITEM "CLASS"
>     CLASS
>       TEMPLATE '../templates/ddarea_query.html'
> NAME "Land"
>       EXPRESSION ('[theme]' eq 'Land')
> 	STYLE
> 	 COLOR	200 255 200
> 	OUTLINECOLOR 32 32 32
> 	END
>     END
>     CLASS
> NAME "Buildings"
>       EXPRESSION ('[theme]' eq 'Buildings')
> 	STYLE
> 	 COLOR	220 220 180
> 	END
>     END
>     CLASS
> NAME "Roads Tracks And Paths"
>       EXPRESSION ('[theme]' eq 'Roads Tracks And Paths')
> 	STYLE
> 	 COLOR	200 200 240
> 	END
>    END
>     CLASS
> NAME "Water"
>       EXPRESSION ('[theme]' eq 'Water')
> 	STYLE
> #	 COLOR	200 200 255
> 	 COLOR	200 240 240
> 	END
>     END
>     CLASS
> NAME "Rail"
>       EXPRESSION ('[theme]' eq 'Rail')
> 	STYLE
> 	 COLOR	180 180 140
> 	END
>     END
>     CLASS
> NAME "Structures"
>       EXPRESSION ('[theme]' eq 'Structures')
> 	STYLE
> #	 COLOR	200 240 240
> #COLOR	180 180 140
> #COLOR	220 220 180
> COLOR	200 200 160
> 	END
>     END
>     CLASS
> 	NAME       "DD Area"
>       STYLE
>         COLOR        232 232 232
>       END
>     END
>   END # DDArea polygon layer ends here
> LAYER # GAZ layer begins here
>     NAME         "gazeteer"
> #    DATA "the_geom from (select g.gid, g.the_geom, g.UPRN, g.purn,
> p.pdc_desc, p.address, p.location, p.system_code, d.band, d.band_date,
> s.total_nav from ((gaz AS g LEFT JOIN domestic AS d on g.purn = d.purn)
> LEFT JOIN shop AS s on g.purn = s.purn) LEFT JOIN property AS p on g.purn
> = p.purn ORDER BY p.location) as subquery USING unique gid using
> srid=27700" DATA "the_geom from (select g.gid, g.the_geom, g.UPRN, g.purn,
> p.pdc_desc, p.address, p.location, p.system_code from (gaz AS g LEFT JOIN
> property AS p on g.purn = p.purn) ORDER BY p.location) as subquery USING
> unique gid using srid=27700"
>     STATUS       ON
>     TYPE         POINT
>     MAXSCALEDENOM 2000
>     TOLERANCE 10
>     PROJECTION
>       "init=epsg:27700"
>     HEADER    '../templates/join_header.html'
>     FOOTER    '../templates/join_footer.html'
> SYMBOLSCALE 1000
>     METADATA
> 	"wms_name"		"gazeteer"
> 	"wfs_title"             "gazeteer" ##REQUIRED
>     END
>    CLASS
>      TEMPLATE '../templates/join_query.html'
>         EXPRESSION ('[purn]' != '')
>         STYLE
>            SYMBOL "circle"
>            COLOR        255 255 255
>  	SIZE 3
>         END
>     END
>    CLASS
> NAME "GAZ NOT matched"
>         EXPRESSION ('[purn]' eq '')
>         STYLE
>            SYMBOL "triangle"
>            COLOR        255 0 0
>            OUTLINECOLOR 255 255 0
>  	   SIZE 20
>         END
>     END
> END # GAZ Point layer ends here
> LAYER # property layer begins here
>     NAME         "property"
>     DATA "the_geom from (select g.gid, g.the_geom, p.purn, p.system_code
> from (gaz AS g INNER JOIN property AS p on g.purn = p.purn)) as subquery
> USING unique gid using srid=27700"
>     STATUS       ON
>     TYPE         POINT
>     MAXSCALEDENOM 2000
>     TOLERANCE 10
>     PROJECTION
>       "init=epsg:27700"
>     SYMBOLSCALE 1000
>     METADATA
> 	"wms_name"		"property"
> 	"wfs_title"             "property" ##REQUIRED
>     END
>     CLASS
>       NAME "Shop"
>       EXPRESSION ('[system_code]' eq 'Shop')
>        STYLE
>             SYMBOL "circle"
>             COLOR 0 0 255
>             SIZE 10
>        END
>     END
>     CLASS
>       NAME "Office"
>       EXPRESSION ('[system_code]' eq 'Office')
>        STYLE
>             SYMBOL "circle"
>             COLOR 255 255 0
>             SIZE 10
>        END
>     END
>     CLASS
>       NAME "Industrial"
>       EXPRESSION ('[system_code]' eq 'Industrial')
>        STYLE
>             SYMBOL "circle"
>             COLOR 0 255 0
>             SIZE 10
>        END
>     END
>     CLASS
>       NAME "Part4"
>       EXPRESSION ('[system_code]' eq 'Part4')
>        STYLE
>             SYMBOL "circle"
>             COLOR 0 255 255
>             SIZE 10
>        END
>     END
>     CLASS
>       NAME "Public House"
>       EXPRESSION ('[system_code]' eq 'Public House')
>        STYLE
>             SYMBOL "circle"
>             COLOR 128 0 255
>             SIZE 10
>        END
>     END
>     CLASS
>       NAME "Hotel"
>       EXPRESSION ('[system_code]' eq 'Hotel')
>        STYLE
>             SYMBOL "circle"
>             COLOR 255 0 255
>             SIZE 10
>        END
>     END
>     CLASS
>       NAME "Contractors"
>       EXPRESSION ('[system_code]' eq 'Contractors')
>        STYLE
>             SYMBOL "circle"
>             COLOR 128 128 128
>             SIZE 10
>        END
>     END
>     CLASS
>       NAME "Genval"
>       EXPRESSION ('[system_code]' eq 'Genval')
>        STYLE
>             SYMBOL "circle"
>             COLOR 255 126 1
>             SIZE 10
>        END
>     END
> END # property layer ends here
> LAYER # shop layer begins here
>     NAME         "shop"
>     DATA "the_geom from (select g.gid, g.the_geom, s.purn, s.floor_area,
> s.floor_red_area, s.floor_eff_area, s.floor_nav ,s.total_nav from (gaz AS g
> INNER JOIN shop AS s on g.purn = s.purn)) as subquery USING unique gid
> using srid=27700"
>     STATUS       ON
>     TYPE         POINT
>     MAXSCALEDENOM 2000
>     TOLERANCE 10
>     PROJECTION
>       "init=epsg:27700"
> HEADER    '../templates/shop_header.html'
> FOOTER    '../templates/shop_footer.html'
> SYMBOLSCALE 1000
>     METADATA
> 	"wms_name"		"shop"
> 	"wfs_title"             "shop" ##REQUIRED
>     END
>     CLASS
> #NAME "Shop"
>      TEMPLATE '../templates/shop_query.html'
>        STYLE
> #            SYMBOL "circle"
> #            COLOR 0 0 255
> ##            OUTLINECOLOR 0 0 0
> #            SIZE 10
>        END
>     END
> END # Shop Point layer ends here
> LAYER # office layer begins here
>     NAME         "office"
> #      DATA         "the_geom from office USING UNIQUE gid USING
> SRID=27700"
> DATA "the_geom from (select g.gid, g.the_geom, o.purn, o.floor_area,
> o.floor_eff_area, o.total_nav from (gaz AS g INNER JOIN office AS o on
> g.purn = o.purn)) as subquery USING unique gid using srid=27700"
>     STATUS       ON
>     TYPE         POINT
>     MAXSCALEDENOM 2000
>     TOLERANCE 10
>     PROJECTION
>       "init=epsg:27700"
> HEADER    '../templates/office_header.html'
> FOOTER    '../templates/office_footer.html'
> SYMBOLSCALE 1000
>     METADATA
> 	"wms_name"		"office"
> 	"wfs_title"             "office" ##REQUIRED
>     END
>     CLASS
> #NAME "Office"
>      TEMPLATE '../templates/office_query.html'
>        STYLE
> #            SYMBOL "circle"
> #            COLOR 255 255 0
> #            SIZE 10
>        END
>     END
> END # Office Point layer ends here
> LAYER # industrial layer begins here
>     NAME         "industrial"
> #      DATA         "the_geom from industrial USING UNIQUE gid USING
> SRID=27700"
> DATA "the_geom from (select g.gid, g.the_geom, i.purn, i.total_area,
> i.final_nav from (gaz AS g INNER JOIN industrial AS i on g.purn = i.purn))
>     STATUS       ON
>     TYPE         POINT
>     MAXSCALEDENOM 2000
>     TOLERANCE 10
>     PROJECTION
>       "init=epsg:27700"
> HEADER    '../templates/industrial_header.html'
> FOOTER    '../templates/industrial_footer.html'
> SYMBOLSCALE 1000
>     METADATA
> 	"wms_name"		"industrial"
> 	"wfs_title"             "industrial" ##REQUIRED
>     END
>     CLASS
> #NAME "Industrial"
>      TEMPLATE '../templates/industrial_query.html'
>        STYLE
> #            SYMBOL "circle"
> #            COLOR 0 255 0
> #            SIZE 10
>        END
>     END
> END # industrial Point layer ends here
> LAYER # part4 layer begins here
>     NAME         "part4"
> DATA "the_geom from (select g.gid, g.the_geom, p.purn, p.total_area,
> p.final_nav from (gaz AS g INNER JOIN part4 AS p on g.purn = p.purn)) as
>     STATUS       ON
>     TYPE         POINT
>     MAXSCALEDENOM 2000
>     TOLERANCE 10
>     PROJECTION
>       "init=epsg:27700"
> HEADER    '../templates/part4_header.html'
> FOOTER    '../templates/part4_footer.html'
> SYMBOLSCALE 1000
>     METADATA
> 	"wms_name"		"part4"
> 	"wfs_title"             "part4" ##REQUIRED
>     END
>     CLASS
> #NAME "Part4"
>      TEMPLATE '../templates/part4_query.html'
>        STYLE
> #            SYMBOL "circle"
> #            COLOR 0 255 255
> #            SIZE 10
>        END
>     END
> END # part4 Point layer ends here
> LAYER # publichouse layer begins here
>     NAME         "publichouse"
> DATA "the_geom from (select g.gid, g.the_geom, p.purn, p.nonresr, p.resr,
> p.finalval from (gaz AS g INNER JOIN publichouse AS p on g.purn = p.purn))
>     STATUS       ON
>     TYPE         POINT
>     MAXSCALEDENOM 2000
>     TOLERANCE 10
>     PROJECTION
>       "init=epsg:27700"
> HEADER    '../templates/publichouse_header.html'
> FOOTER    '../templates/publichouse_footer.html'
> SYMBOLSCALE 1000
>     METADATA
> 	"wms_name"		"publichouse"
> 	"wfs_title"             "publichouse" ##REQUIRED
>     END
>     CLASS
> #NAME "Public House"
>      TEMPLATE '../templates/publichouse_query.html'
>        STYLE
> #            SYMBOL "circle"
> ##            COLOR 0 0 255
> #            COLOR 128 0 255
> #            SIZE 10
>        END
>     END
> END # publichouse Point layer ends here
> LAYER # hotel layer begins here
>     NAME         "hotel"
> DATA "the_geom from (select g.gid, g.the_geom, h.purn, h.nonresr, h.resr,
> h.finalval from (gaz AS g INNER JOIN hotel AS h on g.purn = h.purn)) as
>     STATUS       ON
>     TYPE         POINT
>     MAXSCALEDENOM 2000
>     TOLERANCE 10
>     PROJECTION
>       "init=epsg:27700"
> HEADER    '../templates/hotel_header.html'
> FOOTER    '../templates/hotel_footer.html'
> SYMBOLSCALE 1000
>     METADATA
> 	"wms_name"		"hotel"
> 	"wfs_title"             "hotel" ##REQUIRED
>     END
>     CLASS
> #NAME "Hotel"
>      TEMPLATE '../templates/hotel_query.html'
>        STYLE
> #            SYMBOL "circle"
> #            COLOR 255 0 255
> #            SIZE 10
>        END
>     END
> LAYER # genval layer begins here
>     NAME         "genval"
> #    DATA         "the_geom from genval USING UNIQUE gid USING SRID=27700"
> DATA "the_geom from (select g.gid, g.the_geom, gv.purn, gv.gv_type,
> gv.sit_address_1, gv.buildings_nav, gv.total_adjustment_b, gv.total_ea_val,
> gv.total_adjustment_a, gv.end_allowance2, gv.rounded_nav,
> gv.calculated_rounded_nav from (gaz AS g INNER JOIN genval AS gv on g.purn
> = gv.purn)) as subquery USING unique gid using srid=27700"
>     STATUS       ON
>     TYPE         POINT
>     MAXSCALEDENOM 2000
>     TOLERANCE 10
>     PROJECTION
>       "init=epsg:27700"
> HEADER    '../templates/genval_header.html'
> FOOTER    '../templates/genval_footer.html'
> SYMBOLSCALE 1000
>     METADATA
> 	"wms_name"		"genval"
> 	"wfs_title"             "genval" ##REQUIRED
>     END
>     CLASS
> #NAME "Genval"
>      TEMPLATE '../templates/genval_query.html'
>        STYLE
> #            SYMBOL "circle"
> #            COLOR 255 126 1
> #            SIZE 10
>        END
>     END
> END # Genval Point layer ends here
> LAYER # CBV layer begins here
>     NAME         "cbv"
> #    DATA         "the_geom from cbv USING UNIQUE gid USING SRID=27700"
> DATA "the_geom from (select g.gid, g.the_geom, c.purn, c.sit_1,
> c.adopted_buildings_arc, c.site_works_arc, c.adjusted_site_value,
> c.total_ecv, c.nav, c.ancillary_value, c.redundancy_total,
> c.end_allowance_total, c.total_nav, c.rounded_nav from (gaz AS g INNER JOIN
> cbv AS c on g.purn = c.purn)) as subquery USING unique gid using
> srid=27700"
>     STATUS       ON
>     TYPE         POINT
>     MAXSCALEDENOM 2000
>     TOLERANCE 10
>     PROJECTION
>       "init=epsg:27700"
> HEADER    '../templates/cbv_header.html'
> FOOTER    '../templates/cbv_footer.html'
> SYMBOLSCALE 1000
>     METADATA
> 	"wms_name"		"genval"
> 	"wfs_title"             "cbv" ##REQUIRED
>     END
>     CLASS
> #NAME "Genval"
>      TEMPLATE '../templates/cbv_query.html'
>        STYLE
> #            SYMBOL "circle"
> #            COLOR 255 126 1
> #            SIZE 10
>        END
>     END
> END # CBV Point layer ends here
> LAYER # domestic layer begins here
>     NAME         "domestic"
> #      DATA         "the_geom from domestic USING UNIQUE gid USING
> SRID=27700"
> DATA "the_geom from (select g.gid, g.the_geom, d.purn, d.band, d.band_date
> from (gaz AS g INNER JOIN domestic AS d on g.purn = d.purn)) as subquery
>     STATUS       ON
>     TYPE         POINT
>     MAXSCALEDENOM 2000
>     TOLERANCE 10
>     PROJECTION
>       "init=epsg:27700"
> HEADER    '../templates/domestic_header.html'
> FOOTER    '../templates/domestic_footer.html'
> SYMBOLSCALE 1000
>     METADATA
> 	"wms_name"		"domestic"
> 	"wfs_title"             "domestic" ##REQUIRED
>     END
>     CLASS
>      TEMPLATE '../templates/domestic_query.html'
> NAME "BAND A"
>       EXPRESSION ('[band]' eq 'A')
>        STYLE
> 	    SYMBOL "star"
> #	    SYMBOL "bandA"
>             COLOR 255 0 0
>             SIZE 6
>        END
>     END
>     CLASS
> NAME "BAND B"
>       EXPRESSION ('[band]' eq 'B')
>        STYLE
>             SYMBOL "star"
> #	    SYMBOL "bandB"
>             COLOR 255 255 0
>             SIZE 6
>        END
>     END
>     CLASS
> NAME "BAND C"
>       EXPRESSION ('[band]' eq 'C')
>        STYLE
>             SYMBOL "star"
> #	    SYMBOL "bandC"
>             COLOR 0 255 0
>             SIZE 6
>        END
>     END
>     CLASS
> NAME "BAND D"
>       EXPRESSION ('[band]' eq 'D')
>        STYLE
>             SYMBOL "star"
> #	    SYMBOL "bandD"
>             COLOR 0 255 255
>             SIZE 6
>        END
>     END
>     CLASS
> NAME "BAND E"
>       EXPRESSION ('[band]' eq 'E')
>        STYLE
>             SYMBOL "star"
> #	    SYMBOL "bandE"
>             COLOR 0 0 255
>             SIZE 6
>        END
>     END
>     CLASS
> NAME "BAND F"
>       EXPRESSION ('[band]' eq 'F')
>        STYLE
>             SYMBOL "star"
> #	    SYMBOL "bandF"
>             COLOR 255 0 255
>             SIZE 6
>        END
>     END
>     CLASS
> NAME "BAND G"
>       EXPRESSION ('[band]' eq 'G')
>        STYLE
>             SYMBOL "star"
> #	    SYMBOL "bandG"
>             COLOR 128 128 128
>             SIZE 6
>        END
>     END
>     CLASS
> NAME "BAND H"
>       EXPRESSION ('[band]' eq 'H')
>        STYLE
>             SYMBOL "star"
> #	    SYMBOL "bandH"
>             COLOR 255 126 1
>             SIZE 6
>        END
>     END
> END # domestic Point layer ends here
> #  LAYER # DDAnno line layer begins here
> #    NAME         "ddanno"
> #    CONNECTIONTYPE postgis
> #    CONNECTION "dbname=database user=admin password=password"
> #    PROCESSING "CLOSE_CONNECTION=DEFER"
> #    DATA         "the_geom from ddanno USING UNIQUE gid USING SRID=27700"
> #    STATUS       ON
> #    TYPE         LINE
> #    MAXSCALEDENOM 2000
> #    PROJECTION
> #      "init=epsg:27700"
> #    LABELITEM "text"
> #    METADATA
> #	"wms_srs"		"EPSG:27700"
> #	"wms_name"		"ddanno"
> #	"wms_server_version"	"1.1.1"
> #	"wms_format"		"image/gif"
> #	"wfs_title"             "ddanno" ##REQUIRED
> #	"wfs_srs"               "EPSG:27700" ## REQUIRED
> #	"gml_include_items"     "all" ## Optional (serves all attributes for
> layer)
> #	"gml_featureid"         "ID" ## REQUIRED
> #    END
> #    CLASS
> #      EXPRESSION ('[theme]' eq 'Terrain And Height' OR '[theme]' eq
> 'Structures' OR '[theme]' eq 'Rail' OR '[theme]' eq 'Administrative
> Boundaries'  OR '[theme]' eq 'Land' OR '[theme]' eq 'Water')
> #	STYLE
> ## no color makes this invisible!!!
> #	END
> #    END
> #    CLASS
> #       LABEL
> #          COLOR 0 0 0
> #          TYPE TRUETYPE
> #          FONT "arial"
> #          SIZE 10
> #          POSITION CC
> ##          ANGLE[textangle]
> #       END # end of label
> #    END
> # END # end of layer object
>   LAYER # cartographictext line layer begins here
>     NAME         "cartographictext"
> #    DATA         "the_geom from cartographictext USING UNIQUE gid USING
> SRID=27700"
>     DATA         "the_geom from cartographictext USING UNIQUE oid USING
> SRID=27700"
>     STATUS       ON
> #    TYPE         POINT
>     TYPE         ANNOTATION
>     MAXSCALEDENOM 2000
>     PROJECTION
>       "init=epsg:27700"
>     LABELITEM textstring
> SYMBOLSCALE 5000
>     METADATA
> 	"wms_name"		"cartographictext"
> 	"wfs_title"             "cartographictext" ##REQUIRED
>     END
>     CLASS
> 'Structures' OR '[theme]' eq 'Rail' OR '[theme]' eq 'Land' OR '[theme]' eq
> 'Water')
> 	STYLE
> # invisible!!!
> 	END
>     END
> CLASS
> 	EXPRESSION ([anchorposition] eq 0)
> 		LABEL
> 			COLOR 0 0 0
> 			TYPE TRUETYPE
> 			FONT [font]
> 			SIZE [height]
> 			POSITION ur
> 			ANGLE [angle]
> 		END
> END
> CLASS
> 	EXPRESSION ([anchorposition] eq 1)
> 		LABEL
> 			COLOR 0 0 0
> 			TYPE TRUETYPE
> 			FONT [font]
> 			SIZE [height]
> 			POSITION cr
> 			ANGLE [angle]
> 		END
> END
> CLASS
> 	EXPRESSION ([anchorposition] eq 2)
> 		LABEL
> 			COLOR 0 0 0
> 			TYPE TRUETYPE
> 			FONT [font]
> 			SIZE [height]
> 			POSITION lr
> 			ANGLE [angle]
> 		END
> END
> CLASS
> 	EXPRESSION ([anchorposition] eq 3)
> 		LABEL
> 			COLOR 0 0 0
> 			TYPE TRUETYPE
> 			FONT [font]
> 			SIZE [height]
> 			POSITION uc
> 			ANGLE [angle]
> 		END
> END
> CLASS
> 	EXPRESSION ([anchorposition] eq 4)
> 		LABEL
> 			COLOR 0 0 0
> 			TYPE TRUETYPE
> 			FONT [font]
> 			SIZE [height]
> 			POSITION cc
> 			ANGLE [angle]
> 		END
> END
> CLASS
> 	EXPRESSION ([anchorposition] eq 5)
> 		LABEL
> 			COLOR 0 0 0
> 			TYPE TRUETYPE
> 			FONT [font]
> 			SIZE [height]
> 			POSITION lc
> 			ANGLE [angle]
> 		END
> END
> CLASS
> 	EXPRESSION ([anchorposition] eq 6)
> 		LABEL
> 			COLOR 0 0 0
> 			TYPE TRUETYPE
> 			FONT [font]
> 			SIZE [height]
> 			POSITION ul
> 			ANGLE [angle]
> 		END
> END
> CLASS
> 	EXPRESSION ([anchorposition] eq 7)
> 		LABEL
> 			COLOR 0 0 0
> 			TYPE TRUETYPE
> 			FONT [font]
> 			SIZE [height]
> 			POSITION cl
> 			ANGLE [angle]
> 		END
> END
> CLASS
> 	EXPRESSION ([anchorposition] eq 8)
> 		LABEL
> 			COLOR 0 0 0
> 			TYPE TRUETYPE
> 			FONT [font]
> 			SIZE [height]
> 			POSITION ll
> 			ANGLE [angle]
> 		END
> END
>   LAYER # district_borough_unitary_ward_region layer begins here
>     NAME         "boundary"
>     DATA "the_geom from district_borough_unitary_ward_region USING UNIQUE
> gid USINGSRID=27700"
>     STATUS       ON
> #    TYPE         LINE
>     TYPE         POLYGON
> #    MINSCALEDENOM 2000
>     PROJECTION
>       "init=epsg:27700"
> HEADER    '../templates/dbuwr_header.html'
> FOOTER    '../templates/dbuwr_footer.html'
>     OPACITY 100
>     METADATA
> 	"wms_name"		"boundary"
> 	"wfs_title"             "boundary" ##REQUIRED
>     END
>     CLASS
> TEMPLATE '../templates/dbuwr_query.html'
> 	NAME "Wards"
> 	STYLE
> 	        #COLOR 255 255 255
>         	OUTLINECOLOR 0 0 0
> 		WIDTH 3
> 		#ANTIALIAS TRUE
> 	END
>     END
>   END
> # End of LAYER DEFINITIONS -------------------------------
> END # All map files must come to an end just as all other things must come
> to...
> http://osgeo-org.1803224.n2.nabble.com/Fwd-Re-Fwd-Re-Mapbender-dev-Printin
> g-High-Quality-288dpi-Blank-PDF-tp6520557p6524009.html Sent from the
> mapbender-dev mailing list archive at Nabble.com.
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Im Auftrag
Armin Retterath
Zentrale Stelle Geodateninfrastruktur
LVermGeo RP
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
Telefon 0261/492-466
Telefax 0261/492-492
http://www.geoportal.rlp.de
More information about the Mapbender_dev mailing list
