[Mapbender_dev] [Mapbender] #848: 2.7.x: Count of failure-login by users is not counted
Mapbender mapbender_dev at lists.osgeo.org
Tue Jun 28 12:33:27 EDT 2011
 Reporter:  Anja            |       Owner:  dev
     Type:  defect          |      Status:  new
 Priority:  minor           |   Milestone:
Component:  administration  |     Version:  2.7.1
 Keywords:                  |
 If you´d like to use Mapbender, you´ve got to login first. If the user has
 forgotten his passwort he may try a few times. Usually the number of
 attempts for a failure-login is counted each time.
 In Mapbender 2.7.1 this counting-mechanism does not work.
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/848>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
