[Mapbender_dev] Re: [Mapbender] #774: admin_wmc_metadata does not load when no wmc is in the database
Mapbender mapbender_dev at lists.osgeo.org
Thu Mar 3 03:55:33 EST 2011
  Reporter:  astrid_emde     |       Owner:  dev
      Type:  defect          |      Status:  closed
  Priority:  major           |   Milestone:  2.7.1 release
 Component:  administration  |     Version:  2.7
Resolution:  fixed           |    Keywords:
Changes (by arsgeografica):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Fixed. Instead of returning an error which causes the spinner to "load"
 forever an empty list is given to the GUI which then at least builds an
 empty table which shows the right header.
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/774#comment:2>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
