[Mapbender_dev] [Mapbender] #830: Dynamic print frame: avoid reload with ie
Mapbender mapbender_dev at lists.osgeo.org
Tue May 17 03:27:20 EDT 2011
 Reporter:  astrid_emde  |       Owner:  dev
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  2.7.2 release
Component:  print        |     Version:  2.7.1
 Keywords:               |
 When you use the dynamic print with IE and you want to create a pdf the
 '''data download blocker''' appears and asks whether to download the file.
 Unfortunately after confirmation the whole Mapbender is reloaded. This
 happens at the first print. When you print the second pdf it works fine.
 for more information about the process of the dynamic print have a look at
 #455
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/830>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
