[Mapbender_dev] [Mapbender] #876: Print module
Mapbender mapbender_dev at lists.osgeo.org
Wed Aug 29 02:48:53 PDT 2012
#876: Print module
 Reporter:  armin11         |       Owner:  dev
     Type:  defect          |      Status:  new
 Priority:  major           |   Milestone:  2.7.4 release
Component:  user interface  |     Version:  2.7 rc1
 Keywords:                  |
Comment(by armin11):
 Thanks for the first patch. The is problem still there when using
 mod_jsonAutocompleteGazetteer. It seems to be a problem for the gazetteer
 modul, which zooms to a position and then the move-functionality of the
 print frame is removed. When using mod_WMSpreferencesDiv and the print
 module, they are glued together in one div ? After closing
 mod_WMSpreferencesDiv the print div will not open any longer unless the
 mod_WMSpreferencesDiv is opened :-( .
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/876#comment:6>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
